Old 07-02-07, 08:16 PM
Engine lifting fixture
Hi all,
Am I right in thinking Ford / Chevvy V8 engines are correctly lifted by using a plate with an eye bolt in the middle that is bolted to the intake manifold carb mounting??
I will soon be rigging my engine for transportation to Tim Adams so if I am correct does anyone in the S Yorks / Lincs / N Notts area have said plate I can borrow pls?
Any help apprecaited,
Regards,
Martyn.
Old 07-02-07, 08:35 PM
When I collected my engine from the builder it was set up with this type of arrangement for lifting
When I took it to Reepower for gearbox etc he said he had seen this set up pull the threads out of the manifold before.
He gave me two brackets to lift it by.
David Clifford
AK427, Tremec and Stroker.
Old 07-02-07, 11:54 PM
Clive's Avatar
Hi Martyn, Get some slings from Machine Mart.
Old 08-02-07, 10:25 AM
Engine |Liftin
hi Martyn I've got slings rope chains ets that you can borrow as well as a tripod and block - its big though
Ian
Old 08-02-07, 11:55 AM
Hi Martyn,
The way our engine was lifted by the engine builders and thereafter us was by bolting lifting plates to opposite ends of the heads. If you have edelbrock heads (I don't know if this is standard across the range) there are 2 holes in each end of the head. One on each end is 7/16 UNC (same as 7/16 Whit), and with a bolt in there and lifting plate (to move the sling point above the engine) the engine lifts very nicely. I made up my own from 4mm plate. Basically one is just a flat plate, spaced off the engine by about 25mm (for the rear) and the front has a 45 deg dog leg of about 75mm at the head end to avoid dizzy and thermostat housing, Both straight legs are as long as necessary to clear the head, but from memory they are about 200mm total length. I can take some pics / post some dims if you want but I won't be able to do that until Sunday at the earliest.
Also easier to angle the engine by adjusting the lengths of the strops to each lifting plate if you have two rather than one.
I'm sure somebody will be along with a pic soon to make sense of the drivel I've just written!
Old 08-02-07, 08:40 PM
Big Thirsty's Avatar
Re: Engine lifting fixture
Originally Posted by Martyn-ak427
Hi all,
Regards,
Martyn.
Do not lift your engine using this method, as it can rip the threads. We always lift our engines by bolting lifting plates to opposite ends of the heads. Exaxctly as Jonny T has described it.
Ian
British American Engines / Daytonas
www.britishamericanengines.co.uk / www.badaytona.com
You Tube Channel: http://youtube.com/profile?user=BigThirsty1
Latest Build: Brian Cartmels 330 bhp turn key Chevy 350 C.I. for his Cobra replica http://uk.youtube.com/watch?v=AopjO3wu5rI
Old 09-02-07, 07:26 AM
dave's Avatar
Tuuurn up da bass.
I always use the carb/intake type lift plate and never had a problem. Even when fifting Big Blocks with gearboxes attached.
You must however make sure that the correct threasded studs/bolts are used and are correctly tightened.
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Old 09-02-07, 08:25 PM
Clarkson's Avatar
Speed junkie
Originally Posted by JonnyT
Hi Martyn,
Like this by any chance??
http://i70.photobucket.com/albums/i8...ynopics015.jpg
David
2nd baby due 23rd Jan.
Old 09-02-07, 08:34 PM
dave's Avatar
Tuuurn up da bass.
Dave.
This is great if you don't have a gearbox strapped to the back of it and have no need to change the angle of the engine. Try to fit an engine with a box attached with this and you'll see what I mean.
Pro Dax Builder
Current builds:-
DB REPLICAS
Old 09-02-07, 08:39 PM
Clarkson's Avatar
Speed junkie
Originally Posted by dave
Dave.
Look at the top of the bracket, you can angle it and I fitted my motor with the gearbox fitted.
David
Chevy Engine stand and lifting plate. shadow The Loan Forum 7 06-11-07 02:59 PM
Lifting Experience stevieray General Cobra Discussion 10 25-05-05 11:55 PM
Body fixture locations please madjohnny DAX Technical Questions 8 14-05-05 11:44 PM
Has anyone imported an engine from Engine Factory.com dave General Cobra Discussion 6 01-11-01 11:17 AM
