Old 16-02-07, 02:17 PM
Gearbox alternate oil type needed please
Ok I am using the Tremmec recomended oil Dextron 3 and this seems ok when cold, but the gearbox gets noisy when everything heats up, new gearbox.
I have a friend who works for the company doing the noise testing on tremmec for Ford US, and he says that they are all noisy to greater or lesser degrees but are prety bullet proof, and that ford get the best ones of the line and everyone else just has to take pot luck.
So I will not be changing the gearbox but would like to change the oil for a slightly thicker one that is compatable with the box.
ATF is pretty thin stuff, so my thought is that any good motor racing box oil should be ok, after all it is just gears in there
Anyone able to advise please??
john
WAHOOOOOOOOO: ON THE ROAD AT LAST.:drive:
Got my MSA Licence hillclimbs here I come.......wheeeeeeeeeee!
JUST NEED A TYRE SPONSOR NOW>>>>
Exhausts & headers made by Mark (fat boy northern)
Old 16-02-07, 04:41 PM
I think that if you move away form the recommended stuff, you will start having synchro problems. There is a Royal Purple synthetic oil that has been recommended here by Dr Dee I believe - try a search on "royal Purple" to get the details.
Might just have to put up with the noise..........how do you hear it above the V8 anyway?
Old 16-02-07, 05:13 PM
Sidecarbod's Avatar
I had problems with the my LT77 box and spent quite alot of money on varrious types of oil. Most of them made a smooth gearchange impossible when the oil was cold.
I then tried Redline MTL and can say the change was remarkable!.
I believe others have had similar experiances.
If you do decide to try it be careful as there is a similar product called heavy shock oil (or something like that!)
If the gumph on redlines' website is to be believed it does make interesting reading.
Here's a link:-
http://www.redlineoil.com/products_g...p?categoryID=7
(Open the Tech info PDF)
Regards,
Pete
Old 16-02-07, 05:45 PM
dave's Avatar
Tuuurn up da bass.
Wilf.
He has a hard top, this doesn't help at all when it comes to transmission noise. Think "Days of Thunder" (The Tom Cruise NASCAR movie).
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Old 16-02-07, 06:28 PM
Cobra289's Avatar
RED LINE advises as substitute for the Dexron III the next:
HIGH-TEMP ATF
- synthetic ATF for use where Dexron
III or Mercon is recommended. A higher viscosity allows
optimal operation at 70°F higher temperature, providing
better torque converter efficiency. Provides wear protection
of a GL-4 gear oil. Perfect for heavily-loaded vehicles
and automatic transaxles. Superior stability allows
high-temperature operation without varnishing valves
and clutches which causes failure. Provides the same
low-temperature operation as with a conventional ATF.
I stay by the recommended GM #12345349
TREMEC DOC's
Oil
Caution: NO OIL IN TRANSMISSION. Due to various synchronizer materials used in TREMEC
transmissions, and different climates and applications, no one single fluid will work for all transmissions. We
recommend GM synchromesh part # 12345349, or Dexron III / Mercon Spec ATF fluid for all TKO
transmissions. The transmission should be filled through the fill plug located on the passenger side of the
transmission. Proper fill level is achieved when oil reaches the fill plughole when level (approximately 5.28
pints)
I hope this help!
Cobra289
http://www.donostia.demon.nl
Cobra289 Gallery
"Improvement"¯ means that you recognize previous mistakes!
Old 16-02-07, 07:56 PM
Originally Posted by dave
Wilf.
Then I am surprised he can hear it over the diff noise! LOL
Old 17-02-07, 08:28 AM
Originally Posted by wilf
Wilf.
Wif,
Thanks for the reply.
Dave beat me to it, yes more noticable with the top on.....Diff noise???? can't hear that for the drive shafts clunking.
The disconcerting noise that prompted my post is mainly when stopped and in neutral, If I dip the clutch it goes away but it is only there when every thing is up to temp. Also I can make it louder or quieter by moving the selector.
john
Old 17-02-07, 10:14 AM
Cobra289's Avatar
Hi Snake_bitten,
I have look to your garage and it looks like you are a daily Cobra driver, so you know every small sound or noise of the car very well.
Based on this information I would say that something is going on at the input shaft or components of this shaft.
- Throughout bearing (less probable) because noise goes when you press it.
- Bellhousing out of alignment or a bit loose bolts. Probable due that it forces the input shaft bearing to be inclined and when you depress the clutch there is no movement at this bearing.
- Input shaft bearing (front bearing) Probable it has goat extra play, need to have a larger shim. Desired end plat at the input shaft is 0.000 to 0.004 inch.
- Loose bolts from transmission to Bellhousing. Probable, that can make your input shaft to be inclined and more when it is hot.
- Low oil level. Probable but I think that you all ready have inspected that.
- Wrong oil. Very probable, not that is wrong but that has lost the initial lubrication quality.
I would start by changing the oil and look for the best that you can get. Check and re-check the oil level, too much and the gearbox will leak a couple of drips, but……….. if that helps….
Check all the fixing bolts, Bellhousing to engine and box to Bellhousing.
If this doesn’t help the next step would be check the input shaft end play, move box a bit backwards if that is possible in a DAX of 2008, check with your fingers at the shaft and if you have movements, plan to remove the front bearing retainer (4 bolts) and remove the end play.
It can be done in the car but with a lot of cursing.
I hope that this help, please let us know the results, it is to interesting to know it.
Regards,
Cobra289
Cobra289 Gallery
Old 17-02-07, 01:02 PM
John - what you are hearing is the backlash in the box being taken up in either direction by the relatively slowly-happening firing impulses of the V8 at tickover. You could make it go away or recuce by increasing the tickover - try it. In reality they pretty much all do it - at a standstill, I can make out the same noises as you from my tremec, even without a hardtop, so maybe just learn to live with it and accept it as part of the music your car generates.
Old 17-02-07, 04:49 PM
Thanks Wilf,
Just returned from the garage, I have hopefully eliminated the drive shaft clunking. Masive amount of play between the DiDeon inner CV/driveshaft splines so I have just introduced the splines to Loctite 603.
All being well, one less noise. Also found Gbox touching bolt head on chassis, that is not going to help.
john
What type of paint is needed for the block rsibley Engine Tech Tips & Questions 4 25-09-06 09:40 PM
TKO 500 Gearbox mount hole/thread type bogster General Tech Tips & Questions 0 24-04-06 01:27 AM
Gearbox help needed garyholden General Cobra Discussion 2 12-07-04 07:13 PM
RV8 to Type 9 gearbox peetbee Engine Tech Tips & Questions 4 27-11-03 08:57 PM
Granada Type 9 Gearbox pgoodrum General Tech Tips & Questions 2 28-08-02 09:05 AM
