Old 19-02-07, 04:05 PM
venting the fuel tank
Dax suggest to make a small bypass in the fuel filler hose. This will avoid a vacuum when the tanks feeds the engine by letting in air.
My questions is: is this bypass sufficient? or should I install an additional vent on the tank itself?
Patrick
Old 19-02-07, 05:03 PM
westborne's Avatar
Depends what sort of filler cap you are using.
I recently changed my "Aero" type for a "Le Mans" type and ran a vent from the cap to under the wheel arch.
Seems to work fine
the Aero was vented but the Le Mans from Europa wasn't.
Its only a 3/4mm pipe courtesy of the Neil O workshop - (he did all the drilling and fitting of the connection) What a star that guy is !!
Mines a DB Dax
CHRISC - SW REG REP - Cullompton DB No.46
If Ar*seholes could fly - this place would be an Airport !!
Old 19-02-07, 05:51 PM
I've asked this before but still haven't found the answer. There was thread on here not so long ago about this being absolutely essential for the breathing of the tank (tanks collapsing etc) and I'm going to use the Dax system as it seems to be tried and tested, but wwhere do you put that little tube that they supply - and before we start I know it goes in the filler hose one end , but where does it end up and where should it be fed through?
Old 20-02-07, 07:48 AM
I think the other end should go through the body to the outside, otherwise the fuel fumes will stay inside the boot. I've drilled a small hole and used a grommet that is just the right size to clamp the tube.
Venting the fuel tank kayjayd AK Technical Questions 12 18-10-07 08:27 AM
Sumo fuel tank and expansion tank, chevy pump laosui Parts for sale 0 10-08-07 09:51 PM
Fuel tank venting nbracken General Tech Tips & Questions 18 21-06-07 12:43 AM
Non venting locking fuel cap David Horsnell General Tech Tips & Questions 1 18-09-03 05:46 PM
Fuel Tank Venting martin DAX Technical Questions 3 26-04-03 03:07 PM
