| Warren Is it a Jaguar or BMW Getrag, or how many splines has your output shaft, as I have a clutch alignment tool for 10 spline.
| Are you fitting new components together or components that have already been together before? If they are new did you try the clutch plate on the gearbox input shaft to make absolutely sure they will fit together and have the correct size splines? If a new spigot bush has been added to the crank shaft are you sure it the right internal diameter to fit the gearbox shaft? Could the clutch release bearing be too thick and holding off on the clutch cover? How big is the gap between the bell housing and the engine when you attempt to get it together? I have fitted many clutches to all sorts of engines in the past and have never used anything more than a socket extension bar, various sockets and a roll of masking tape to make the correct size. Never had any problems fitting any of them together. Craig.
| Cheap Clutch alignment tool..... http://www.holden.co.uk/productSearch.asp# enter 'clutch aligning tool' in the keyowrd search box. Have used one several times with no problems. Cheers Geoff |
| Hi Warren, If you can, get hold of an old Rover input shaft they are 1" x 23 spline, that's what I used on my Jag Getrag clutch. If you can't find one give me a PM & you can borrow mine. Steve
__________________ AK 427, Chevy 350 If you can make it - MAKE IT! |
| Clutch Alignment Tool Craig, I know, both myself and my old man have done this more times than we care to remember. You can guess the gap, about 3/4inch, just the spigot end that will not slot home. Re-checked alignment, it just won't have it. It's all been together before, the only item changed is the bell housing. My only other thought is to leave it on the studs, put the slave back together and operate the clutch, just to give me a bit of waggling room. If not it's going to have to come out again and with the steel bellhousing it's a right sod. Geoff, thanks for the link and Steve, I could well be in touch if I can't get what I need. Cheers Warren |
| Re: Clutch Alignment Tool Quote:
Hopefully I have attached a copy of the article I recently wrote for the club mag.
| Clutch Alignment Tool Yes, dialled in. Didn't even leave it to my amateaur efforts, I took the whole lot up to a local V8 specialist, Performance Unlimited and he did it for me. Sent for a new alignment tool and will have another go next week. Warren |
This thing is plastice and works by attaching the friction plate to the pressure plate with a dubious taper rod that opens the 'spigot' end up like a rawl bolt. You then turn this over and align the friction plate centrally to the cover plate face using your best visual judgement. You depend on the tightness of these 'plastic' components to then hold it securely in place whilst you bolt it up to the flywheel......oh yes...that'll work...not. I wouldn't even bother with the blood, sweat and tears involved in offering it up, think I'll wait for the real deal to arrive. Is it just me or is this Cobra ownership thing just a tad tedious..didn't I read somewhere about a valuation service involving the exchange of a crate of beer...circa 20K (too scared to add the invoices up) would've bought me a 600bhp skyline with a proper roof Warren |
| Rover V8 Clutch alignment | CeeJay | General Tech Tips & Questions | 9 | 12-03-08 12:43 PM |
| ford TKO clutch alignment tool | snake_bitten | The Loan Forum | 1 | 11-04-07 08:24 PM |
| Clutch Alignment Tool for Chevy | garyholden | The Loan Forum | 9 | 27-07-06 09:59 AM |
| Clutch alignment tool | Iain | General Cobra Discussion | 3 | 27-01-05 04:07 PM |
| Clutch Plate Alignment | choogh | General Tech Tips & Questions | 9 | 03-07-02 11:04 PM |
