| Clutches Again - Urgent Info Required! Hi Guys, Im after some urgent info regarding gearbox installation. I have aligned the plate & clutch & then installed the clutch / bellhousing onto the block. The jag getrag splined shaft slides into the clutch however it stops there & only with a little force, (nipping up the mounting bolts) will it begin to go into the pilot bearing, (I got it about half way along but then became concerned about causing damage). I then retracted the gearbox & noted a slight scuff mark inside the pilot bearing where the shaft enters. Can anyone advise pls if a certain amount of force is required to get the gearbox fully located or should it slide in freely? Any assistance appreciated. Regards, Martyn
__________________ AK with tyre-lighting 393ci Ford Stroker - 480hp & 475ft/lbs! - (build about 90% complete..) "Girdles Are For Fat Chicks Not Engines" |
| Warren, Thanks for the info & I am happy to advise I have managed to get the gearbox to slide into place without the use of any kind of "persuasion" I managed it by basically doing what you advise below & just gradually manipulating it into place. I think the problem was basically plate to clutch alignment. I may be wrong but I also thought there was a little bit of stiction between the pilot bearing & the snout of the splined shaft? I am fortunate in the fact that my body is not on so I could work around the gearbox so I do not envy you in your position so wish you the best of luck. Regards, Martyn
| Jaguar 3.6 XJS - Urgent Info required | Martyn-ak427 | General Cobra Discussion | 4 | 15-08-05 10:32 PM |
| URGENT - Help Required | Daz Johnston | Pilgrim Sumo Technical Questions | 17 | 17-02-04 09:45 AM |
| URGENT - YOU MAY BE ABLE TO HELP | FELIX | General Cobra Discussion | 11 | 16-08-02 03:43 PM |
| SVA Guidelines Book - URGENT URGENT | robert | General Cobra Discussion | 7 | 27-03-02 08:44 AM |
| sticky clutches | sideoiler | Snake Watch & Industry News | 9 | 19-05-01 04:43 PM |
