| Hope this helps mate, http://www.5speedtransmissions.com/h...chpkgpics.html You have to weld that metal bracket to the bell housing under the top bracket as you can see in the above link I would sell that bell housing and get the repower setup with a ali bellhousing slave cylinder kit. Here is an other idea from someone else on this forum that I saved on my PC,below.
__________________ David SR Cobra, 350 Chevy, 120db sidepipes with flames on overrun!! 2nd baby due 23rd Jan. Listen to my 350 idling. http://uk.youtube.com/watch?v=IauqIQuOX0E Last edited by Clarkson; 06-07-08 at 08:07 PM. |
| Well done Dave, it's been bugging me, never mind Si
| Quote:
| Hi Sparticus, Probably this picture will help you. It is not my setup but from someone else. I can see that is welded under the existing bell housing bracket. Hope this help to make the decision. When you weld to the bell housing, I would keep it installed and let cool down very slow, do in this way you will shore that no stress will be introduced. Regards, Cobra289
__________________ http://www.donostia.demon.nl Cobra289 Gallery "Improvement" means that you recognize previous mistakes! |
| Quote:
| It was your setup I saved on my PC Mr Bogster.
| Right, i welded the mounting plate to the chassis at the weekend and i'd just like to say a big thank you to everyone that helped. I've also attached a couple of pics. I was kind of concerned at the angle that the slave and rod seem to be following but i have enough travel and i'm pretty certain it'll do the job, especially seeing as its a ball joint.
__________________ Dax De Dion c/w Chevy 383 - Scaring old ladies, animals and children with the popping from my exhaust |
| Hi, It looks pretty nice, good weld too. The angle looks a bit to much, but it would be possible to correct it now that is outside the Cobra. My advise is to grind the plate with and angle to get a better push line. I have made a fast drawing with your picture and I can see that you have a 13 degree angle, this can introduce a bit friction. Check the picture, you have the space, and when you grind the plate, say 8 degrees you will have a perfect setup. This is just and opinion, nothing more. Regards, Cobra289
| From experience, I also believe you should try to improve that angle. Hydraulic cylinders do not like side loadings - it promotes very rapid wear. It is going to be far easier to improve this now while the engine is out, than a year later when you have it installed and a pool of hydraulic fluid on the floor and no clutch.
| New Clutch Slave problem | Sparticus | General Tech Tips & Questions | 15 | 02-05-07 12:15 AM |
| Clutch slave cylinder | PaulF | General Tech Tips & Questions | 3 | 22-01-05 06:07 PM |
| Clutch slave | Goldie | AK Technical Questions | 5 | 23-09-04 11:36 PM |
| Which Clutch Slave do I need? | BenBaron | Engine Tech Tips & Questions | 3 | 11-10-03 10:49 AM |
| Dax Clutch slave cyl. | DavidSaw | General Cobra Discussion | 2 | 20-08-02 11:00 PM |
