| Quote:
I would definitely remove the angle as your slave cylinder will wear out very quickly.
| Quote:
| well..... i buffed back the plate i welded on till it was flat.... drilled the angled hole till it was straight.... then tapped a half inch unc hole....put in a solid state cast helicoil with threadlock.... buffed off the top of the helicoil till it was flush with the welded bracket (so flush you can't even tell i've modified it) painted it red ....and hey presto on straight bulletproof clutch slave bracket Thanks for all the help guys.....engine hopefully going in tomorrow or saturday!!!!!!
__________________ Dax De Dion c/w Chevy 383 - Scaring old ladies, animals and children with the popping from my exhaust |
| What we can say other than; WELL DONE MATE! You will love it. 100% straight. Regards, Cobra289
__________________ http://www.donostia.demon.nl Cobra289 Gallery "Improvement" means that you recognize previous mistakes! |
| Well done mate,lets hope it clears your footwell!
| Quote:
This is one of the best setups for our Cobras. You need to take in account the fork ratio and the pedal ratio to have a little pedal effort, but this is the best start. Ford gearboxes have more problem because the fork ratio is to low and the pivot is located at the wrong place. Regards, Cobra289
| Sooooooo, tried to fit the engine tonight.... Engine and gearbox fits in (though i'll probably take it out and grind a bit more off the bellhousing because its so bloody close) Mounting bolts DAX very kindly sent me F.O.C with my throttle cable are too short Also despite cutting a small section out of the chassis webbing, my fuel pump hose is hitting the steering Universal Joint (my plan to fix this is to by a 90deg fitting that i can angle away from the UJ) so looks like all work on the car is screwed for this weekend unless someone local has two 7/16 x 4" high tenisile bolts the can give me. Typical, just when you feel like you're making progress and you have everything you need
| Don't worry - that is minor stuff, we all face $hite like that. Nothing ever fits just how you would like...........
| New Clutch Slave problem | Sparticus | General Tech Tips & Questions | 15 | 02-05-07 12:15 AM |
| Clutch slave cylinder | PaulF | General Tech Tips & Questions | 3 | 22-01-05 06:07 PM |
| Clutch slave | Goldie | AK Technical Questions | 5 | 23-09-04 11:36 PM |
| Which Clutch Slave do I need? | BenBaron | Engine Tech Tips & Questions | 3 | 11-10-03 10:49 AM |
| Dax Clutch slave cyl. | DavidSaw | General Cobra Discussion | 2 | 20-08-02 11:00 PM |
