| good point, will take some photos tomorrow. My car is miles from my house so was trying to get a rough guess. Anyway, will take photos of all the bits and pieces. Thnx
__________________ Dax De Dion c/w Chevy 383 - Scaring old ladies, animals and children with the popping from my exhaust |
| The bracket for our clutch slave was especially made up for the job. The bracket is then bolted onto the bell housing - there are plenty of bolt holes into which studding can go to hold things on.
| Slave Cylinder Mounting Hi Sparticus I had the same head scratching question. I just bought some angle iron (slave cylindar mounted 90 degrees to the bellhousing face) and cut it with a hacksaw to fit behind the bellhousing, secured to the bellhousing using the bell housing bolts (needed the odd spacer washer). Was not very difficult to do but I have not tested it yet. The only problem I did have was squeesing the bracket and slave into the chassis as the assembly stuck out the side of the engine/gearbox further than the chassis would allow so I had to remount it a little and cut back some of the sheet steel of the chassis (not structural). This was a pilgrim so this may not be a problem on some other cars. Sorry I don't have a picture available but could get one to you if you need it. All the best John |
| Slave Cylinder Mounting Sorry, to clarify, NOT behind the bellhousing, the bracket is mounted using two bolts holding the bellhousting to the block behind the rim of the bellhousing..... |
| Just wondering if anyone has any ideas now i've uploaded some pics. I'm really desperate to get my engine in Thanks Si
| And I am equally desperate to try to work out WTF those bits are for! All I can say for sure is that your slave needs to push from the engine side. Think I will call "surrender" on what that steel brakcet is meant to be.
| New Clutch Slave problem | Sparticus | General Tech Tips & Questions | 15 | 01-05-07 11:15 PM |
| Clutch slave cylinder | PaulF | General Tech Tips & Questions | 3 | 22-01-05 05:07 PM |
| Clutch slave | Goldie | AK Technical Questions | 5 | 23-09-04 10:36 PM |
| Which Clutch Slave do I need? | BenBaron | Engine Tech Tips & Questions | 3 | 11-10-03 09:49 AM |
| Dax Clutch slave cyl. | DavidSaw | General Cobra Discussion | 2 | 20-08-02 10:00 PM |
