| Fuel CAP wing recess dimensions Hi, I am trying to change the fuel tank setup on my DAX. One of the points that I like to change is the fuel cap location. I like to put on top of the wheel box with the nice recess. Can you please give me the dimensions of the recess? Top diameter. Bottom diameter Height Location? I will try to laminate one my self. Thanks for your help. Regards, Cobra289
__________________ http://www.donostia.demon.nl Cobra289 Gallery "Improvement" means that you recognize previous mistakes! |
| Hi Mark, Thanks for the advise. I don't know if the DAX will fit my design, The location is very important for me, the hose will run inside the wheel box, what I mean is that the the fuel tank inlet tube will run against the rear of the wheel box. I need to know the DAX location so that I can decide how to do it. Regards, Cobra289
| I think you will find there is plenty of scope to de able to fit it where ever you like. I believe it is fitted by fixing it from the underside with P38 or is that P40
| Quote:
DITTO.
| I don't know what means P38 or P40, is that a polyester glue or epoxy glue? Anyway I will check with the Benelux importer and see if he has the part. Does it have all ready the round shape of the wheel box? The car is all ready painted so I need to work with care to have a minimum paint rework. Thanks! Regards, Cobra289
| Quote:
| Thanks TINKA, That is what I did suspected. Regards, Cobra289
| retrofit fuel cap recess | Cobra power | DAX Technical Questions | 9 | 23-01-07 03:12 PM |
| retrofit fuel cap recess to body | Cobra power | DAX Technical Questions | 3 | 17-10-06 08:54 PM |
| Fuel tank dimensions...PLEASE!!! | madjohnny | DAX Technical Questions | 19 | 26-11-04 05:32 PM |
| Fuel tank dimensions | CobraMat | DAX Technical Questions | 13 | 23-02-04 08:57 PM |
| Do Dax bodies have a recess for the fuel filler as standard? | BenBaron | General Tech Tips & Questions | 7 | 17-11-03 09:03 AM |
