| Hi Sparticus, Here we are again, I hope that we can help you. You mention two options, one is using Teflon(R) Teflon is possible to use with Brake Fluid, it will resit with out problems. All the flexible brake lines (braided type) have the inner core from Teflon. But be aware from the next: If you apply Teflon don't put tape close to the start thread, that it can goes inside the hole. You can never turn back a thread that is sealed with Teflon, if you do that you loose the sealing. So it should go at once to the final position. Second you talk, if I understand it correct about a Banjo bolt. This would be the cleanest solution. Remove the brass fitting and change for one that has the Banjo setup. For that you need to go to a brake shop, because they would have the special fitting. Probably your actual brass fitting has a thread of 3/8"-24 but you need to check. I hope this help. Regards, Cobra289
__________________ http://www.donostia.demon.nl Cobra289 Gallery "Improvement" means that you recognize previous mistakes! |
| Can you not remove it and get a flexible pipe that screws directly into the slave cylinder and joint it to the copper pipe on the chassis, you don't want a copper pipe directly screwed into to the cylinder as it will flex with the engine and will eventually break
| sounds like you need a banjo fitting,like this?? If so call Faye at speedflow and she will sell you one.
__________________ David SR Cobra, 350 Chevy, 120db sidepipes with flames on overrun!! 2nd baby due 23rd Jan. Listen to my 350 idling. http://uk.youtube.com/watch?v=IauqIQuOX0E Last edited by Clarkson; 06-07-08 at 08:07 PM. |
| YES!
__________________ Dax De Dion c/w Chevy 383 - Scaring old ladies, animals and children with the popping from my exhaust |
| Hi, The setup that you see at Clarkson picture uses a "Repower" slave cylinder. This cylinder has a flat surface where a banjo bolt can be sealed with a copper or aluminum ring. Yours doesn't have that flat sureface, so it will not work. The banjo that I was mention has a different shape. Check the picture, the first part need to be sealed with Loctite (R) blue, the top section would be the banjo system. See pictures You also can try to use an standard elbow, one side should fit the slave cylinder and the other side will connect to the -AN fitting of your hose. I hope this help. Regards, Cobra289
| Yes I can see the pics,but I must be missing something here?? Why can't use use the brass fitting you have fitted and use a straight male fitting on your clutch pipe?? Speak to speedflow they will have an answer.
| Quote:
Sounds like all you have to do is change the pipe fitting from banjo to male which is very easy.
| Quote:
| its also a pig to get in to tighten the brass 90degree bend or attach anything to it. So far my best option is (bearing in mind my clutch setup is american)... 1/8npt male to male connector (going directly into the clutch slave) 1/8npt female to 3/8 UNF female connector and then bolt my banjo fitting on (this way i can always tighten it with a socket easy because i've got more access) Just wondering if a 1/8npt-3/8unf female connector exists or would i have to fabricate one.
| Clutch Slave Cylinder Problem | twincamrider | General Tech Tips & Questions | 11 | 16-12-07 11:17 AM |
| Clutch slave | Sparticus | General Tech Tips & Questions | 39 | 20-04-07 09:26 PM |
| Clutch slave | Goldie | AK Technical Questions | 5 | 23-09-04 11:36 PM |
| Which Clutch Slave do I need? | BenBaron | Engine Tech Tips & Questions | 3 | 11-10-03 10:49 AM |
| Dax Clutch slave cyl. | DavidSaw | General Cobra Discussion | 2 | 20-08-02 11:00 PM |
