Old 22-06-07, 11:16 PM
Just before I start her up.....
Its all together, oil pressure up and tight, no fuel leaks, and she turns over on the starter... a couple of final (final for this stage !) questions..
1.Has anyone got a photo of the rotor arm position with static timing at 8 deg BTDC (just for my peace of mind) (RV8 with Lucas DLM.
2. How do you clean out the glass fuel filters (some initial muck visible), do they dismantle?
3. On the Holley 390 carb, whats the unused pipe in attached phot? What's the neatest way of blanking off these redundant pipes?
Standing by.....
QK
Old 23-06-07, 07:41 AM
dave's Avatar
Tuuurn up da bass.
1. I can't help.
2. Throw it away and get a steel one.(Glass fragile, fuel explosive etc.)
3. Servo take off.
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
Old 23-06-07, 09:41 AM
robinj66's Avatar
The answer to No 1 is going to depend on where the lead for No 1 plug is attached to your distributor cap.
Old 23-06-07, 09:42 AM
rich's Avatar
What Dave says
This was caused by a glass filter cracking and its not been the only one
You know it makes sense
rich.
All Things Cobra.Com
the cobra builders resource
Old 23-06-07, 09:46 AM
If you have already taken a feed for your servo then this pipe might be for the PCV if you have not already sorted this out. As has already been pointed out get rid of the glass filter as soon as you can.
Old 23-06-07, 10:01 AM
slogger's Avatar
Originally Posted by rich
What Dave says
DEFO get rid of the glass! I had a fire and if the filter bowl had been glass the car would have been totaled!!!!
http://autos.ninebean.com/cobraclub/...op+bonded+body
Is this the same car as your pic Rich?
Edit: Should open my eyes.....only one hoop!
Ian DAX 454 Chevy
Old 23-06-07, 10:07 AM
rich's Avatar
This ones a Sumo Ian
Not sure what caused the fires on the other thread
rich.
Old 23-06-07, 10:57 AM
Before i start
Many thanks for the fuel filter advice, I will get on to that right away. The brake servo is taken off the stub pipe at the front of the Offy manifold. Do I need a PCV if I have a filter & air filter connections from the rocker cover? Is the carb connection now surplus?
Many thanks
QK
Old 23-06-07, 11:17 AM
Re: Before i start
Many thanks
QK
Yes you will need a PCV set up no matter what. Normally if you have the appropriate fitting on each rocker cover you need to connect one to the port in your picture via a PCV and vent the other one to the atmosphere or connect it to the air filter.
Old 23-06-07, 03:15 PM
Veteran polisher.
In a slight bit of defense for the glass filters, I have one fitted to my car but it is on the vacuum side of the system between the tank and the pump. This is mounted under the car away from any sort of heat and has a cover to protect from stones or flying debris.
The only problem I have had so far is when I didn't tighten the two halves of it together tight enough and although it didn't leak fuel it did suck air into the pump.
This is the only filter I have on my car and I can't see a need for any more. In my opinion one filter is enough and keep it as close as possible to the tank.
How many petrol production cars do you see with a fuel filter under the bonnet?
Polishes to date = 17
First Start up Almost !! cliffords Engine Tech Tips & Questions 20 20-05-07 05:28 PM
How do you start?? bitsilly Ram Forum 3 21-01-06 06:34 PM
Now it won't START MacGD016 Engine Tech Tips & Questions 26 05-10-04 11:30 AM
Hot Start or Not!!!! Steve Faithful General Tech Tips & Questions 7 18-05-04 07:46 PM
Just Won't Start Jules_ Pilgrim Sumo Technical Questions 4 13-01-04 12:36 PM
