Old 24-06-07, 08:35 PM
martin_t's Avatar
Replacing Spigot Bearing
Hi
Can anyone give me advice on taking the old spigot bearing out from a rover 3.5? Seems pretty well stuck in. The Rover manual says force it out with grease but that doesn't seem plausable. Any idea's or experiences?
Thanks
Martin
GD427 Mk4 - Chassis rolling.
MK4 Body ordered (in black)!!
GD Chassis J0258.
www.martins-cobra.co.uk
Old 24-06-07, 08:42 PM
steamyrotter's Avatar
Serial Complicator
Re: Replacing Spigot Bearing
Originally Posted by martin_t
Hi
Thanks
Martin
I bent a piece of reasonably thick welding rod into a u shape with large hooks bent on the ends. Forced it in through the centre and allowed the hooks to spring out behind the bush.
Jammed a screwdriver in the U which helped spread it then levered it out. Protect the journal with a packer so you don't score it.
Worked for me but then it wasn't stuck that hard in the end.
Hope that helps
Dean.
Old 24-06-07, 08:53 PM
rich's Avatar
Hi
Thanks
Martin
The grease method does work, fill as much of the cavity as possible and get a shaft/socket that is a good fit to the hole.
if using a socket, then fill that with grease as well, and give it a good thump with a rubber mallet. Hydraulics should do the rest
You know it makes sense
rich.
All Things Cobra.Com
the cobra builders resource
Old 24-06-07, 10:12 PM
The grease method works well. You need a solid rod/bar thats a good fit in the bearing. Alternatively, I have used a small sharp cold chisel CAREFULLY to run a split down the bush then collapse it.
Stan
Old 24-06-07, 10:54 PM
slogger's Avatar
I got the old Chevy bearing out, that was stuck fast, by tapping the hole with a course thread. Wit-worth or UNC and then screwed in a bolt with the head cut off. Fitted a slide hammer to this and whacked it out.
Ian DAX 454 Chevy
Old 24-06-07, 11:02 PM
The clutch alignment tool works fine for this
Myles D-W
Old 01-07-07, 11:08 PM
martin_t's Avatar
The grease method worked, thanks for the advice!
Martin
GD Chassis J0258.
Replacing Big End Bearing Shells johnnycobra General Tech Tips & Questions 2 11-07-04 07:50 PM
Spigot Bearing Clearance Barry Davolls Engine Tech Tips & Questions 5 06-05-04 06:36 PM
Crankshaft Spigot Bush Phil McCann Engine Tech Tips & Questions 7 26-03-04 11:33 AM
RV8 Spigot bearing perky Engine Tech Tips & Questions 6 06-06-03 08:33 AM
Water pump/fan mounting spigot beanpole Engine Tech Tips & Questions 5 28-04-03 08:55 AM
