  #21 (permalink)
Old 10-07-07, 05:21 PM
Simon R's Avatar
Originally Posted by dingocooke
Not too keen on fixed cylinders anyway, theyre pushing against a lever whose contact point is moving in an arc, and even though its approx 200mm rad, the contact point if recessed to take the ball end of the rod, will move enough to bind the cylinder somewhat and make the clutch action heavier. I think it wqould make a much better job if the back of the slave cylinder was mounted on a pivot, but I suppose its an extreme length to go to.
Looking at what youve got there, a little 'adjustment' of the bracket angle should get you in position; I think you should be able to take the bracket off, pop it in a vice and tweak it with a soft mallet; t doesnt look like it will need much to get in in the right position; or as previously suggested, you could make a spacer to move the cylinder bracket out; looking at your pic Im guessing a spacer cut from 5/16" or 8mm ally plate will do the trick.
The cylinder isn't fixed - the push rod has a pivot at the piston - as the piston moves out the lateral play in the pushrod increases - so there would not be any tendancy to bind.
I'm liking the idea of "adjustment" - if anything it may make me feel better!
No-one got a photo of the angle of their bracket?
Simon.
GDJAG
Chassis Now Rolling!
BAE 383 SBC in and running
MKIV Body fitted
What's Next
http://str-427-cobra.blogspot.com/
  #22 (permalink)
Old 10-07-07, 06:27 PM
andy l's Avatar
ref slave cylinder
Hi Simon
Had the same problem with my braket it was 70 degs, ground off welds and re welded at new angle 78 degs hope this helps Andy
DAX TOJEIRO DE DION
CHEVY SB 383 STROKER 6.2Ltr 450 Hp
Tremec TKO 3550 3.54.1 Jag Diff
RCR Mk 1 GT 40 in build
  #23 (permalink)
Old 10-07-07, 07:18 PM
Simon R's Avatar
Re: ref slave cylinder
Originally Posted by andy l
Hi Simon
Thanks Andy...... I think that's proved it for me!
GDJAG
MKIV Body fitted
What's Next
  #24 (permalink)
Old 11-07-07, 12:50 PM
Orange Cobra's Avatar
Simon drop Ian a line at BAE I`m sure that he`ll be able to solve that problem for you.
Regards Frank
SBF 393,TKO600,Anti Radar Paint, Nobody can stop us now , nobody!!
  #25 (permalink)
Old 11-07-07, 01:09 PM
Simon R's Avatar
Regards Frank
Thanks Frank - Ian's allready on to it.
GDJAG
MKIV Body fitted
What's Next
  #26 (permalink)
Old 11-07-07, 01:25 PM
Veteran polisher.
I thought speaking to Brian at Re-Power would be a good idea seeing as he supplied the bracket.
Maybe he had some dodgy ones made that had the wrong angle when they were welded together.
Polishes to date = 16
  #27 (permalink)
Old 11-05-08, 09:17 PM
conrod's Avatar
Apologies for bumping an old thread here, but it's directly relevant to issues I'm having with the RePower SBC clutch slave cylinder and bracket!
My clutch started slipping on the way to Stoneleigh last year. A quick chat with Dave Brookes on his stand and I was able to adjust the length of the rod on the slave cylinder. However, there was very little thread left for any subsequent wear/adjustment. A year on, and the clutch started slipping again. Shortening the rod as far as it would go (i.e no thread left!) there was still no free play. And worse still, after this adjustment the clutch pedal wouldn't move at all - seized solid!
Further inspection revealed that the bracket was at too acute an angle - the actuating rod was out of true and was seized on the washer that prevents overthrow of the slave cylinder. I solved this by sandwiching an old Allen key between the rear of the cylinder and the bracket to get the rod in better alignment.
Inspiration then struck me, and I inserted 10mm spacers between the slave mounting bracket and the bellhousing to give me more adjustability on the rod thread. So, I now have a working clutch again - but it's all a bit of a bodge!
I'm going to get a new bracket made up with less acute angle - 78 rather than 70 degrees (as per a previous post by Andy L in this thread) sounds about right. That will remove the need for the Allen key spacer bodge. If I also have either a second pair of holes for the slave cylinder mounting drilled 10-15mm further back, or have two slots rather than two holes, that will remove the need for the 10mm spacer bodge.
I should add that I'm not heavy on the clutch. However I suspect with the limited free play I've had, this may have caused premature wear on the clutch plates - though on both occasions that clutch slip has been evident, I've taken remedial action straight away.
My question is this. If I've effectively had to shorten the rod by 10mm in order to get free play in the mechanism, does this mean that my clutch plates are now near their serviceable limit? I might just give Repower a call tomorrow - but has anyone else had this problem?
Alan
Thames Valley Area Rep
My Gallery - click here
My Albums - click here
Clutch slave Sparticus General Tech Tips & Questions 39 20-04-07 08:26 PM
repower clutch slave cylinder aero340 General Tech Tips & Questions 3 04-08-06 10:32 PM
Clutch slave Goldie AK Technical Questions 5 23-09-04 10:36 PM
Which Clutch Slave do I need? BenBaron Engine Tech Tips & Questions 3 11-10-03 09:49 AM
Dax Clutch slave cyl. DavidSaw General Cobra Discussion 2 20-08-02 10:00 PM
