Old 25-08-07, 01:46 PM
Starter Circuit
Guys,
I am going to rig up a temporary electrical circuit to allow me to start my engine for the first time in the chassis but as my knowledge of electrical wiring is cak I am wondering if anyone has a basic starter / alternator wiring diagram they could email to me?
Regards,
Martyn
Old 25-08-07, 05:57 PM
kevchard's Avatar
Hi Martyn
To get it started you dont actually need the altenator circuit connected.
All you need to do is connect a 12v feed from the battery to the starter solenoid, a big red wire to the starter terminal, everything earthed then bobs your uncle. That stands unless you have electronic ignition, then add a heap load of wires into the equation.
Hope that helps.
Kevin
Kevin & Helen
DMS Venom Viper
Granada Cosworth 2.9V6 BOA
SVA passed Aug 07
Old 25-08-07, 06:48 PM
If you don't connect the alternator then you will more than likely fry it. It will need a load on it and the easiest way is to wire it to the battery so that it will charge it.
Old 25-08-07, 07:06 PM
Thanks so far guys.
I have gotton this far upto now:
battery wired to starter & earth on chassis.
small diameter cable wired from push button starter to starter solenoid.
coil wired to battery, earth & dizzy.
radiator cooling fan wired to battery & earth.
All I have left to do is wire the alternator. I presume this is just a case of taking the alternator terminal wires to the battery live & chassis earth?
I am a complete numpty when it comes to auto wiring so if I have overlooked anything let me know.
Regards,
Martyn
Old 25-08-07, 07:28 PM
kevchard's Avatar
And the altenator 'sense' wire to the red charge light on the dash.
Our ford granada altenator was fine for monthsw with no wires to it duting the testing days .
Kevin
PS Hope yu get a video or mp3 of the noise Martyn
Kevin & Helen
DMS Venom Viper
SVA passed Aug 07
Old 26-08-07, 11:57 AM
steamyrotter's Avatar
Serial Complicator
Failing that take the belt off for the mean time..
If its just a test run you don't need to turn the alternator.
This is all assuming your belt does not turn anything else of course?
Dean.
Old 26-08-07, 06:57 PM
Club Sec/Rep Liason
The Water Pump is quite important Dean
AK 427 351C T5wc
Old 27-08-07, 11:40 PM
Serial Complicator
Ah ignore me then.......
Only know about my engine and how it is bodged together. I could (and did) take the belt off as it only operated the alternator.
Mind you it is a rover so nuff said!!
Dean.
Old 28-08-07, 04:39 PM
Cobra289's Avatar
Talking
Originally Posted by Martyn-ak427 View Post
Thanks so far guys.
Regards,
Martyn
I hope that you don't forget to wire the Push Stop Button!
Sorry I could not resit the temptation!.
Regards,
Cobra289
http://www.donostia.demon.nl
Cobra289 Gallery
Old 28-08-07, 05:10 PM
dingocooke's Avatar
Regards,
Cobra289
or pop wire cutters in your pocket...
Steve
We're here for a good time...
Dual Circuit brakes Harry-G General Tech Tips & Questions 1 07-03-06 07:55 PM
Goodwood Circuit? Sheik yerbouti Events 0 22-04-04 08:30 AM
Tachometer circuit required adricar2 General Cobra Discussion 4 08-12-03 08:52 PM
Rev counter - circuit Steve Faithful General Tech Tips & Questions 1 27-03-03 08:47 PM
Toggle On/Off circuit millsd60 General Tech Tips & Questions 22 06-08-02 09:20 AM
