Old 27-08-07, 08:11 PM
Daxman's Avatar
Carter 4600 fuel pump
Hi guys,
I've aquired one of these pumps but can't find much info about it? would it be o.k to use with a carb.
I have looked at many pics and it seems to be alot bigger than the ones you guys fit. It has a silver body where as the ones i have seen have a gold colour body. It has also come with 1/2" hose fittings which is to big for my solid pipe (10mm), can i reduce these fittings to 3/8" or will this cause the pump to stall or overheat.
Many thanks
Russ
DAX DE DION - HUDDART 383
Old 27-08-07, 09:06 PM
carter pump
Russ, the 4600HP is rated @ 100 GPH and 6-8 PSI, doesent need a regulator. Its roughly the same as Holley Red Top , should be OK......Mike
Carter Electric fuel pump Question bogster General Tech Tips & Questions 10 13-06-06 11:19 PM
fuel pump lordy Pilgrim Sumo Technical Questions 13 12-08-05 12:06 PM
new fuel pump MARTIN123 General Tech Tips & Questions 1 21-01-05 05:10 PM
Fuel Injection fuel pump problem. Poohbear Engine Tech Tips & Questions 20 11-05-04 11:53 AM
EFi Fuel Pump SWP952 General Tech Tips & Questions 14 25-03-04 03:09 PM
