| Tightening NPTF Water Fittings My SBC came with straight heater outlets on the manifold and pump - these aren't particularly usefull for routing the heater hoses. So I've got a coupe of -10 elbows and 1/2" NPTF to -10 adaptors. When I go to fit the adaptors they only go into the pump / manifiold about 1 turn until hand tight. I appreciate that NPT threads have to deform to help form a seal (along with some ptfe tape) so there would be some resistance? Question is... how much do I tighten them? I've read somewhere that 3 turns beyond hand tight would be OK for up to 1" Obviously I don't want to break anything! Also I assume that NPTF will screw into NPT? Thanks in advance. Simon.
__________________ GDJAG Chassis Now Rolling! BAE 383 SBC in and running MKIV Body fitted What's Next ... SVA? or IVA? probably IVA!http://str-427-cobra.blogspot.com/ |
| [quote=Simon R;203424]My SBC came with straight heater outlets on the manifold and pump - these aren't particularly usefull for routing the heater hoses. So I've got a coupe of -10 elbows and 1/2" NPTF to -10 adaptors. When I go to fit the adaptors they only go into the pump / manifiold about 1 turn until hand tight. I appreciate that NPT threads have to deform to help form a seal (along with some ptfe tape) so there would be some resistance? Question is... how much do I tighten them? I've read somewhere that 3 turns beyond hand tight would be OK for up to 1" Obviously I don't want to break anything! Also I assume that NPTF will screw into NPT? Thanks in advance. Hard to say,I have used these fittings on my car and I only nip them up maybe 1/2 a turn. Don't forget to use plummer tape or they will leak. Never heard of NPTF?? only NPT.
| NPTF is the higher spec version of NPT intended for Fuel but the dimensions are the same. NPTF is intended to be dry-seal (no sealant required) but this will only work where both fittings are NPTF which is not the case with an inlet manifold.
| Tightening BSW Bolts | mylesdw | General Tech Tips & Questions | 3 | 15-01-08 12:55 AM |
| Tightening brake Union Fittings | Martyn-ak427 | General Tech Tips & Questions | 7 | 13-11-06 10:55 AM |
| Water fittings | h8jse | Engine Tech Tips & Questions | 22 | 17-02-06 11:50 PM |
| Tightening fuel fittings and testing pressure | Robin427 | General Tech Tips & Questions | 10 | 17-09-04 11:54 AM |
| Fuel, Brake & Water - Pipes and Fittings and more! | Colin | General Tech Tips & Questions | 0 | 12-06-02 03:08 PM |
