| I have fitted a Facet Red Top with an inline regulator to limit the pressure down to around 5psi. Yes it is advisable to use an inline filter between the tank and the pump although the pump has it's own filter in the bottom. Driven to France and back without incident. Paul |
| Ideally you should fit a filter between your tank and the pump and another between pump and carb
| Fuel Pump. I bought my fuel pump from Real Steel for just over £50. They recommended a Carter unit. I'm using it with a Weber 500 on a RV8 4.0 litre engine with no problems. It came with all the required unions, etc for plumbing in. One of their main comments was that it runs very quietly in comparison to many of the other units. |
| I have had a Carter pump for 6 years and 20k miles - no problems. Whereas on my old car, the facet pump crapped out on me much earlier. The "quietness" of the Carter is a relative thing - they still make a racket.
| I think it depends on the installation, the Carter in my Crendon makes quite a bit more noise that the old Facet in my RAM, both rubber mounted in an almost identical way and position, the Facet on my Hawk sounded terrible though, but it wasnt very flexibly mounted. I think the mounting makes all the difference so spend time and money on that if you dont want too much noise. Put a filter king (non glass type bowl) filter and pressure reg in your engine bay, it will take the water and crud out of the fuel, and save you gas from the pump pressure overcoming the float needle/seat and flooding/running rich.
| Quote:
I have fitted a carter and have removed the fuel pressure guage 'cos it's glass as well.
__________________ billy no mates . South East Regional Rep SRV8 |
| Quote:
I can only hear my Carter pump before I start up. Mounted in the boot, driver's side with the bobbins supplied with the pump. I did make a spreader plate to mount it to, and this was Werthed to the fibreglass to give a liitle more sound deadening. Go for the Carter pump, Facets are gay.
__________________ Crendon, Ford Sideoiler 427 |
| fuel pump | lordy | Pilgrim Sumo Technical Questions | 13 | 12-08-05 12:06 PM |
| Fuel Injection fuel pump problem. | Poohbear | Engine Tech Tips & Questions | 20 | 11-05-04 11:53 AM |
| EFi Fuel Pump | SWP952 | General Tech Tips & Questions | 14 | 25-03-04 03:09 PM |
| Fuel pump | Shaney23 | General Tech Tips & Questions | 4 | 30-12-03 07:03 PM |
| Fuel Pump | Miket | General Tech Tips & Questions | 14 | 17-12-01 08:05 PM |
