| Quote:
Is it a Sumo ??????????????
| Its a viper of some description - lord only knows who actually made it!
__________________ Got engaged on xmas day so I have 15 months to get the cobra finished so I can drive it to my own wedding - I'd best get the finger out... |
| Quote:
Re the switches, you can use toggle switches and anything else without the correct radius as long as they are within the exempt area as shown in enclosed pic.
| Quote:
CeeJay.
| Quote:
If these are the ali type sold by carbuilder solutions, then you should be OK. I used these, along the bottom of the dash binnacle, so outside the exclusion zone. I originally had the teardrop style toggle, that I changed for the domed one for sva purposes. However, to help it pass I also made some protectors, consisting of ali rod with threaded ends bent into a semi-circular U-shape with a pipe bender. These I bolted (nutted?) through onto the dash either side of each switch. The protectors have the correct radius for SVA and prevent mr sva's ball touching the offending switch - basically the same solution that BMW have used on the new Mini. No problem for my sva test, but may depend on the test centre you use. Kevin
__________________ CAP 326Y finally road legal. Pilgrim Mk III RV8. |
| Thanks for the emails guys! I'll probably just fit rocker switches to get me through the sva - then I'll fit proper flick witches. Thanks again for the replies! CeeJay.
| Rear / Brake light | Uncle Dickie | General Tech Tips & Questions | 2 | 07-05-07 11:02 AM |
| Dax rear light bulbs | Nobby | DAX Technical Questions | 2 | 06-09-05 09:07 PM |
| rear near side wheel spacing | perky | Pilgrim Sumo Technical Questions | 3 | 25-04-04 06:49 AM |
| Rear light fitting | beanpole | Pilgrim Sumo Technical Questions | 7 | 08-09-03 11:32 AM |
| Stylish labels / plaques for dashboard flick switches | Adegould | General Tech Tips & Questions | 16 | 07-11-02 09:25 PM |
