| Brake / hydraulic fittings Hi All When you attach brake pipes to master cylinder or caliper, or when you attach hydraulic pipe to the clutch master & slave, do you use any Locktite thread locker? or do you just tighten up the fittings? Just want to make sure.
__________________ Regards Richard Dax - Standard Chassis, 383 Stroker (Tremec TKO v. soon) |
| Thanks for the advice Pete. When I was doing some work on my Citroen I thought I saw a little threadlocker around the fittings. That started me thinking.
| I think all hydraulic fittings are intended to seal dry, as thread lock etc wouldnt be any use at hydarulic system pressure; like pete sidecar bod Ive never used it on these fittings, and never had anything come loose racing (Ive had the reverse problem in the paddock though...cant get the bugger undone)
| Brake pipe fittings sizes | simon finlay | General Cobra Discussion | 3 | 01-05-07 01:00 AM |
| Tightening brake Union Fittings | Martyn-ak427 | General Tech Tips & Questions | 7 | 13-11-06 10:55 AM |
| Brake fittings | Pat | General Tech Tips & Questions | 5 | 08-07-04 06:46 PM |
| Brake Caliper Size Fittings | BenBaron | General Tech Tips & Questions | 9 | 17-02-03 10:44 PM |
| Fuel, Brake & Water - Pipes and Fittings and more! | Colin | General Tech Tips & Questions | 0 | 12-06-02 03:08 PM |
