| Don't use any washers but do use lock nuts. The ones on my diff are a metal locking type nut. Not he ones with the nylon insert. I guess these have a proper name but I'm not sure what it is. The nuts on the driveshafs from the diff to the wheels on the jag are the same type. I just do them up very tight with normal length ring or open ended spanner if thats all you can fit in there. Haven't had any come loose yet.... Craig.
| you MUST use the genuine Jaguar nuts and bolts for this application. They are a "Non-Preferred" diameter and ordinary nuts and bolts will run the risk of slackening off. If you don't want a propshaft failing and flying through the floor adjacent to your left buttock, use the Jag bolts. I know they are expensive, but worth it!
| Good point Clive. The correct bolts have an un-threaded section that fills the holes in the diff flange and the prop shaft. I was supplied ordinary bolts with my prop shaft but I used bolts supplied by Wards. Jag is the place to get them from or one of the specialist jag dealers like Ward engineering, SNG Barrett Etc. Craig.
| Quote:
I`m glad I re-used mine from the donor now.
| Loctite 243 removal | Spanish Dave | General Tech Tips & Questions | 6 | 18-09-07 09:32 AM |
| Jag propshaft bolts | Clarkson | General Cobra Discussion | 27 | 02-02-06 10:43 PM |
| Desparate plea - Jag propshaft bolts?!!! | smash | General Cobra Discussion | 13 | 10-09-05 10:50 PM |
| Diff -> Propshaft bolts | paolo | Pilgrim Sumo Technical Questions | 6 | 17-05-05 11:28 PM |
| Propshaft bolts | saviller | Pilgrim Sumo Technical Questions | 2 | 23-11-04 05:49 PM |
