| Quote:
LEO, Redline MTL is not an ATF oil it is a fully synthetic 70/80 gearbox oil, so I'm not sure why you think that is is no good for an LT77. Pete
| Quote:
but must say not a fan of Ellis myself but I stuck with what he recommended in view of my previous experiences and the fact the unit carried a 1 year warranty. But hang on a moment was not Peter Jones singing his praises some time back in Snake Torque? I think you will find Russell Ram and Cheng Lim also advise the type oil I mentioned
__________________ Leo Sinclair Some cause happiness wherever they go; others, whenever they go. DMS Venom, Rover 4:6, Jaguar, Mega-Squirt, MSD, Eaton M112 |
| Quote:
| Quote:
If your bored you should have a read of the PDF doc on the Redline website, its quite interesting if you like oil and all things oily! Pete
__________________ I refuse to engage in a battle of wits with an unarmed opponent. Last edited by Sidecarbod; 25-03-08 at 03:58 PM. |
| Quote:
Tremec....what do they know! just because they have built tyhe odd gearbox here and there they think that that gives them the right to go specifying oil willy-nilly Seriously though, if they designed their box right from the start so that it would work correctly with ATF then that could be why they specify it. The syncro timing and levels of friction of the syncro rings may have all been designed around ATF. I don't think that the LT77 box was designed round ATF, that oil was specified later when people moaned about the slow gear change when cold. Having said all that I know that oils that are not designed for the extreme loads between gear teeth get their polymer chains shredded by being put through gears, I still don't think that ATF was ment to be used in this way. AJMHO. (My get out clause). Pete
| The thing that I find funny is the (unspoken) assumption that auto gearboxes somehow don't have gears in them, and so don't need an EP oil. ![]() Of course they do, and they work just fine with some massive torque ratings, and only ever ATF in them. However, I always did wonder about the use of ATF in an "old" box like the Rover unit, surely they were designed to use an EP oil to begin with?
| Quote:
My car runs very well using mid range Comma 20W/50 mineral oil which I change every 500-1,000 miles with filter, resulting in 75psi when cold and 50psi when hot & 25lb @ idle, so my point is that some folk who suggest using a cheaper oil ruins an engine are talking pants
| Quote:
| LT77 Gearbox | David Large | General Tech Tips & Questions | 18 | 02-08-07 07:26 AM |
| LT77 Gearbox ID | Speedy Gonzales | General Tech Tips & Questions | 2 | 12-07-06 08:03 PM |
| LT77 gearbox | tonym | Engine Tech Tips & Questions | 12 | 18-05-06 12:57 PM |
| LT77 Gearbox | qkingston | Engine Tech Tips & Questions | 2 | 02-05-06 01:34 PM |
| LT77 gearbox | chesterak | Engine Tech Tips & Questions | 4 | 02-04-05 08:31 AM |
