Tinka, didn't mean to sound rood. I think the main issue is trapped air as RCCob's setup does not allow for any trapped air to be expelled.
Just read back and Demus has already covered what I have posted.
Ian DAX 454 Chevy The closer I get to getting it running, the further away I actually am!!
Ian pointed me in the direction of this thread. Cheers
I did add a breather pipe from the top hose back to the header tank in my Chevy powered Dax. The Dax solution is a £75 thermostat housing with an additional pipe stuck in the side but I added my own pipe to the top hose. Any welding / fabrication shop should be able to do this. The pipe can be seen in the attached photo. It is the pipe that goes from the top hose to the top of the header tank. It allows any air trapped in the engine to go to the highest point then vent back into the header tank. Craig.
Dax Tojeiro, + 350 Chevy + Tremec box = no more money! Polishes to date = 14
The reason Tinka didn't have a problem is because the AK header tank has the breather built in and the pipe goes to an outlet on the top of the Rover SD1 rad.
Mike AK Sportscars 355 Hauser Chevy The old believe everything, the middle-aged suspect everything, the young know everything. |
Cheers Mike.
wish full thinking I know. |
Before you drive the car again please, please, please remove that fuel filter.
Those glass or plastic filters will not withstand the heat directly above an engine and will split, crack or leak sooner or later spraying fuel under pressure onto the top of a very hot engine. There is really no need to have a filter under the bonnet. Keep it at the rear of the car away from any heat and vibration. If you really insist on one under the bonnet then get a Filter king filter housing and mount it firmly on the bulkhead. Good luck with the cooling system. Cheers Craig.
| Cooling System | fatcat | General Cobra Discussion | 0 | 17-12-07 10:53 AM |
| Cooling system | T-Bone | General Tech Tips & Questions | 1 | 17-11-07 10:50 AM |
| Cooling System | Kevin Smith | DAX Technical Questions | 9 | 07-05-04 09:31 PM |
| Cooling system | brianp | Pilgrim Sumo Technical Questions | 3 | 18-01-04 05:10 PM |
| Cooling system query | simon | General Tech Tips & Questions | 16 | 08-01-03 10:28 PM |
