| Quote:
Cheers Craig it was the previous owner who fitted it. That will now be put to the top of my list of jobs for tomorrow, I did wonder why there was two filters fitted, there is one in the boot as well. Cheers Russ |
| Quote:
| That's good Russ. I have seen too many kit and custom cars with filters mounted on top of the engine. Very dangerous practice. One filter is enough really. You should have one before the electric pump and that's it. Quite a few people fit one after the pump but I have never seen the need. The coolant bleed tube on my car goes from the top of the thermostat / top hose and goes back to the top of the header tank. This is just to vent air from the highest point back to the header. It is a small pipe though to limit the amount of coolant that will flow through the pipe back to the header. Too much flow and it will divert water flow from the radiator. Craig.
| Quote:
| Quote:
RCCob has stated that he doesn't to mod / weld the tank so I think he his talking about using the vent connection at the cap. RCCob please can you confirm what you intend to do.
__________________ Ian DAX 454 Chevy Life is short! Break the rules! Laugh uncontrollably and never regret anything that made you smile. Last edited by slogger; 05-04-08 at 10:55 PM. |
| Ian If Russ adds a bleed tube to the header tank it will have to be a new pipe fitting welded in the top of the tank below the cap level. Craig.
| Quote:
__________________ Ian DAX 454 Chevy Life is short! Break the rules! Laugh uncontrollably and never regret anything that made you smile. |
| Quote:
Regards Russ |
| Cooling System | fatcat | General Cobra Discussion | 0 | 17-12-07 11:53 AM |
| Cooling system | T-Bone | General Tech Tips & Questions | 1 | 17-11-07 11:50 AM |
| Cooling System | Kevin Smith | DAX Technical Questions | 9 | 07-05-04 10:31 PM |
| Cooling system | brianp | Pilgrim Sumo Technical Questions | 3 | 18-01-04 06:10 PM |
| Cooling system query | simon | General Tech Tips & Questions | 16 | 08-01-03 11:28 PM |
