  #31 (permalink)
Old 11-05-08, 02:55 PM
RCCob's Avatar
RCCob RCCob is offline
Update
Originally Posted by TINKA View Post
Make sure you have left the heater control open so that the water can circulate properly, if you turn it off you need a bypass so the water can still circulate or it will always boil over. Had this problem on mine.
As someone else has said though where do you fill the system up.
Hi Tinka, I think I found what the problem was with the over heating. I was trying to get the air out of the system after fitting the bleed from top hose to the header tank when I noticed the rad was fitted UP SIDE DOWN So I then went about removing the rad and refitted it the correct way up, best part of 3 hours work. Now the question is, I don't have a bypass for the heater fitted but there is a shut off valve in front of the heater, which I have fixed in the open position. Can I just fit a Y connector in to the pipe work. I want to be able to Turn off the heater, or do I need a special valve?
Russ
  #32 (permalink)
Old 11-05-08, 05:30 PM
TINKA TINKA is offline
Russ
Yes as long as the water can circulate it should all be fine as far as by passing the heater goes
Cooling System fatcat General Cobra Discussion 0 17-12-07 10:53 AM
Cooling system T-Bone General Tech Tips & Questions 1 17-11-07 10:50 AM
Cooling System Kevin Smith DAX Technical Questions 9 07-05-04 09:31 PM
Cooling system brianp Pilgrim Sumo Technical Questions 3 18-01-04 05:10 PM
Cooling system query simon General Tech Tips & Questions 16 08-01-03 10:28 PM
