| Solid State Fuel Pumps I have read recent threads re Fuel Pumps with interest, is there any reason why the Facet Solid State (Fast Road 4-5.5 psi) doesn't seem to get a mention? Being Solid State it would sound more reliable and they claim it is quieter? |
| Ok that's understood, I have a RV8 but somewhat tweaked (230bhp), what minimum fuel pressure should I be providing? Rgds QK |
| I had a red top on a std chevy,but not very relible and it packed up after 2 years. Now fitted a holley which is good but very noisy.
| Quote:
EFI - different kettle of fish altogether.
| Quote:
As stated though EFi is different altogether. The pump has to prime a fuel " rail" which has a return line to the main fuel tank or to a swirl pot tank. this as a positive pressure of around 8 psi is usual in the fuel rails - even if the engine is not running but ignition on you would expect to have around 8psi and flow through the rails. This is why EFi systems usually demand a reliable high flow pump to be installed. The fuel pressure and flow flow rate in an EFi system is critical, which is why most will install a swirl pot in the system so that at least a litre or so of fuel is always available to the fuel rails, which is not always the case when cornering or with low fuel quantity from a standard system pick up point in the tank.
__________________ Chris Lutman - Daytona Coupe |
| PSI is only one of the issues when it comes to fuel pumps, the total volume of fuel delivered per minute is very important and this is "sort of" independent of the PSI although the PSI will drop if the delievery rate that is required can not be met by the pump In A.Bells book on 4-strokes He recons that you can multiply the expected BHP figure by 4.6 and that will give you the total amount of fuel required per minute in CC (More is required for "blown" engines for some reason or other). I guess this is why you can find 2 or 3 pumps all working in parallel in some gas gusling monsters, the PSI will not be mutlipied by the number of pumps but the total amount of fuel will be assuming that they have separate feed pipes to the carb or a least one big one. 230 BHP is going to need just over a litre per minute to keep the float bowls full. Thats my two pence worth! Pete
| Quote:
(But flat out is what the pump needs to be able to cope with, or you'll get a nasty lean off). Pete
| My old RAM (302 ford with full ED RPM kit heads etc Holley 600cfm mech secondaries) was on a Facet goldtop from being built (still on it too), ran really well, and the facet was actually a fair bit quieter than the Carter pump on my Crendon.
| Facet Fuel Pumps | qkingston | General Tech Tips & Questions | 2 | 16-09-07 11:48 AM |
| solid fuel line | Daxman | General Cobra Discussion | 4 | 13-02-06 01:38 AM |
| Fuel pumps | dave.n | General Tech Tips & Questions | 18 | 22-02-05 09:04 PM |
| Noisy Fuel Pumps | nick206 | General Cobra Discussion | 13 | 05-09-03 05:08 PM |
| Jag fuel pumps | andybearne | General Cobra Discussion | 3 | 02-05-03 02:10 PM |
