| Jag rear brake upgrade Hi Guys, A while back there was a thread about upgrading brakes. I don't intend to go the AP route as it will be mainly a road car, but someone did mention that replacing the rear solid discs with vented versions was a major improvement. Can anyone tell me where I can get vented rear discs from please? Wards and Gordons do drilled versions but not vented. Also who sells Pagid brake pads?
__________________ Best regards, Richard Dear GD427J0217/Mk 3 body/Ford 351W Engine Factory/TKO600/3.54PL diff/S-type narrow rear drive shafts. It's going to be red!!!! |
| Quote:
IIRC its a bugger to get the old normal size calipers to fit never mind any wider versions. Perhaps there is an opportunity here for a vented disc rear brake conversion using a more modern single piston caliper ? Cheers, Tony
| Yes that's the one I was thinking of but it doesn't mention vented rear discs. It must have been another thread. Spoke to Ed at Wards and he said that he used to do a vented kit many years ago but did not think it was worthwhile unless you were doing some serious track work. Tony, just had a look at the Jag rear set up and you're right, there is not enough room for a vented disc. You would have to replace the caliper and then probably lose the handbrake. If anyone knows any different let me know?
| Or you could fit XJ40 uprights and halfshafts to get outboard brakes which are a bit easier to play around with and cool. |
| Brake upgrade | k40bra | General Cobra Discussion | 9 | 22-04-08 03:19 PM |
| Sierra Brake Upgrade | Marty V6 | General Tech Tips & Questions | 0 | 16-02-08 10:20 PM |
| brake upgrade | JOHN C | Pilgrim Sumo Technical Questions | 10 | 29-03-05 08:45 AM |
| Brake Upgrade for jag base | v8robert | General Tech Tips & Questions | 1 | 02-03-05 06:36 PM |
| Brake Upgrade | mikey | General Tech Tips & Questions | 4 | 22-09-02 12:11 PM |
