| Lucas DLM8 I have a Lucas DLM8 Dissy (the one with the module attached to the side of the dissy) on the RV8, before I start up for the first time I wonder whether someone could help me with a little info. In order to set up the timing correctly, does the module sit in between the valley, or outside the left cylinder bank. The dissy won't rotate round because the module comes into contact with the cylinder head, so it has to be one or the other. None of the pictures I have seen with DLM8s are clear enough to tell. Many thanks QK |
| Lucas DLM8 Thanks Russ, I have noted from a previous comment by Jim (JRV Rgds QK |
| The problem I think is with fouling both the head and the main coolant outlet from the manifold. My distributor has the advance can and module at 180 and it works fine - however, I have a Defender type front cover (pump slightly different position/shape) and an Edelbrock manifold. In any case, if you position it so you have max available rotation, then you ought to be able to time it as long as it's close to start with. Russ Last edited by russell_ram; 15-04-08 at 06:47 PM. |
| Lucas, wiring ! | Steen | General Tech Tips & Questions | 4 | 13-01-08 11:32 PM |
| Lucas switches | ianhunter | General Tech Tips & Questions | 5 | 01-03-07 04:12 PM |
| "New" DLM8 Distributor does not work proberly | Kassi | Engine Tech Tips & Questions | 10 | 12-11-06 05:05 PM |
| RV8 DLM8 DIZZY + MSD6AL | DrFelch | General Tech Tips & Questions | 7 | 26-02-04 04:11 PM |
| rv8 lucas 2ce ignition | markg | General Tech Tips & Questions | 1 | 13-06-03 07:09 PM |
