Old 11-05-08, 09:34 AM
andicole0's Avatar
andicole0 andicole0 is offline
It takes how long!
Security devices
How far have you gone with any vehicle security device? Alarm, imobiliser, tracker?
Anyone any experience of the imobiliser supplied by Dax (from their loom supplier).
Cheers.
Andi.
http://picasaweb.google.com/andicole0 - http://andiscobra.blogspot.com/
Old 11-05-08, 03:42 PM
Russ-Notts's Avatar
Russ-Notts Russ-Notts is offline
Security Devices
Andi,
A Thatcham approved Cat2 immobiliser is pretty much a 'must-have' and will normally get you a discount on your Insurance. An audible alarm system (Cat1) is usually more trouble than it is worth in my experience. The ultrasonic detectors need careful setting up for convertibles otherwise you get loads of false alarms. I don't have much experience on Trackers. Quite expensive but will lead you to the location where the joy-ride left your Cobra burnt out. I've not used the DAX immobiliser you mentioned.
Whatever you decide to fit, it is probably worth a call to your Insurance company to see if they have a preferred device or manufacturer. Some Insurance companies also insist that they are professionally fitted and that you have a certificate to say so.
1984 Dax Tojeiro.
Rover 3.5 with Holley
Jaguar 3.54 PL differential
Pat Hanson chassis
Old 11-05-08, 06:54 PM
Daxman's Avatar
Daxman Daxman is offline
Hi Andi,
I was thinking of fitting one of these,
<strong>TOAD</strong> Text Alert GSM mobile security system. New
It has a built in pay as you go sim card and texts you if the car is tampered with, and an output which could be used to isolate the fuel pump or ignition.
Russ
DAX DE DION - HUDDART 383 - 452bhp & 466lbft Torque
Old 11-05-08, 07:12 PM
scoop scoop is offline
I opted for a hidden master switch which only leaves the alarm and courtesy lights on when the switch key is removed. this does mean you need 2 fuse boxes but thats no problem.
The alarm I fitted (15 years ago) was a Gemini. I don't believe this company are in business anymore so if it ever goes wrong I'm snookered, It has a small box which I think is some form of microwave sensor (thats how it was advertised), adjustable range so it can be set for the cockpit with tonneau on. it also incorporates an imobiliser which is in the Low voltage side of the ignition.
Old 11-05-08, 11:45 PM
tarmacscratcher's Avatar
tarmacscratcher tarmacscratcher is offline
Removable steering wheel can make it pretty hard to steal
www.betterbiker.com
Old 11-05-08, 11:59 PM
TINKA TINKA is offline
Yes that is the way I went as well. Hopefully when some Ar5# #### takes a fancy to my car hopefully seeing there is no steering wheel will stop him from tearing out half the electrics to try and get it started.
After all if they really want it no alarm is going to stop them anyway.
Old 13-05-08, 02:23 PM
claude3c claude3c is offline
im planning on a biometric fingerprint system can only start engine if your finger print is in the mini computer data base - may not work but im investigating it at mo
Car Security robert General Cobra Discussion 16 27-09-05 10:54 PM
Programmable devices and SVA. steamyrotter General Tech Tips & Questions 14 24-04-05 09:29 PM
Security Crafty1980 General Cobra Discussion 5 11-06-04 04:33 PM
For those with Windows devices robert The Cockpit 0 01-08-03 12:11 PM
Security How do you do it. Jnex26 General Tech Tips & Questions 6 20-12-02 09:25 AM
