Old 11-05-08, 11:29 AM
bluetoon's Avatar
bluetoon bluetoon is offline
Sierra collapsible column
Guys,
I want to check that the sierra steering column i am using is sva compliant. ie collapsible.
Could someone point me to the bits on the column that are collapsible,
Im not sure, but the bottom column has 'bellows'. Is that the collapsible part, if it is then i will need to use that one.
or is it the extension part that is 'collapsible'.
I spent alot of time shaping the cowling to fit the dash which will have been in vain if i need to use the other column.
Jim
How are the doors and bonnet supposed to fit again ? .
Old 11-05-08, 12:15 PM
TINKA TINKA is online now
The bottom column has what appears to look like bellows but this is not the collapsible portion.If you look at the other end you will see the triangle section that slides inside the outside piece is held with white nylon bushes inside, this is the collapsible section.
Old 12-05-08, 09:44 PM
michaelf michaelf is offline
Thumbs up sierra steering column
Originally Posted by bluetoon View Post
Guys,
Jim
Just to add a little more to Tinka's comments. The bottom of the triangular shaft that extends from the base of the steering column then fits onto an intermediate shaft which in turn connects to the steering rack. Now, the problem is, if left unmodified, there will be a gap between the bottom of the triangular section and the top of the shaft that connets to the steering rack. Most people would say that the solution would be to get an extended lower shaft from the rack to the base of the steering column. This is solution 1.
What i did was to connected an extra short collapasable section between these two shafts. This short extra piece was from a sierria, (an XR4I i think). Doing this does make the lower section rather wobbly, but so long as this portion is securely supported, then it will get through the SVA. Mine Did. Although Mr SVA man looked at it, he didn't say that there was anything wrong with it.
I hope the above helps and just keep going.
Mike
Old 12-05-08, 10:01 PM
gareth08's Avatar
gareth08 gareth08 is offline
This is also the bit that is much better welded up once you have extended the shaft
Mines been like that for 5 years now and it hasn't injured me yet even passed SVA like it as well
Gareth
Sumo Ford/T5 w/c and Nos
Old 12-05-08, 10:07 PM
JonnyT JonnyT is offline
Probably something many moons away but the SVA guy asked about the safety devices on our steering column. The correct answer is that the column is collapsible but also that the UJ's on the intermediate shafts are offset adding the necessary second element of collapsibility.
Jon
Sierra column switches Daxman DAX Technical Questions 4 28-03-07 09:40 PM
Sierra Steering Column wsnaith DAX Technical Questions 4 11-03-07 03:51 PM
Sierra column Splitpin General Tech Tips & Questions 3 14-01-05 06:11 PM
Sierra column stalks - Again ! Jake General Cobra Discussion 7 04-10-04 08:41 PM
Sierra Column and switches. futureproof DAX Technical Questions 4 05-05-04 12:14 PM
