Old 15-05-08, 10:09 PM
RCCob's Avatar
RCCob RCCob is offline
Question What gear box have I got?
Hi Guys I have a small problem with the gear box. When I'm changing down gears from third to second I keep shoving it through the reverse gate. I need to find out what box it is so I can replace the gate spring. I have a 3.5 RV8 fitted, any help appreciated.
Russ
Old 15-05-08, 10:16 PM
slogger's Avatar
slogger slogger is offline
Russ
Post a picture of your box and selector remote. Most 3.5 SD1 had an LT77 if 5 speed, but when fitted in a Cob the remote differs from a shortened SD1 to a Sherpa van type and others.
Ian DAX 454 Chevy
Old 15-05-08, 10:28 PM
RCCob's Avatar
This is only pic I have at the moment, also the bolt you can see in the center of the mounting bracket seems to be just a bolt with a piece of rubber round it and not a proper mounting bush, is this correct?
Old 15-05-08, 10:40 PM
slogger's Avatar
Yep, it looks like an SD1 LT77. That is an SD1 gear box mount you have and the centre bolt goes through a rubber bobbin that locates into a hole in the cross member. I believe this is to limit the movement of the tail end of the gearbox.
As for your gear selector remote, I can't really comment as it is not visible.
Ian DAX 454 Chevy
Old 15-05-08, 10:47 PM
TINKA TINKA is offline
When I had my old RV8 & LT77 I had a similar problem, in the end I changed the gear stick to one that looked original but was actually functional so you had to lift the bar to be able to get it in reverse, and that solved the problem. Can post some pictures of what I did if you want, think I have some somewhere. HTH
Old 15-05-08, 10:52 PM
slogger's Avatar
If you have the shortened SD1 remote, it is only a case of setting the spring pressure with a couple of bolts and lock nuts. All in the Haynes manual for the Rover. I set mine so you had to snap it across to get reverse.
Ian DAX 454 Chevy
Old 15-05-08, 10:53 PM
RCCob's Avatar
Thanks guys the pics would be a great help Cheers
Old 15-05-08, 10:55 PM
RCCob's Avatar
Thanks will give that ago before trying any mods to gear stick
Old 15-05-08, 10:56 PM
slogger's Avatar
Have a look here:
LT77
Good luck.
Ian DAX 454 Chevy
Old 20-05-08, 05:55 PM
RCCob's Avatar
Have a look here:
LT77
Good luck.
Hi Guys had a look at the drawings Still no better off, Can some one put this in plane speak for me. I have taken a couple of pics Sorry not very good they were taken with me phone. Are these the adjustable nuts you were taking about?
Cheers Russ
Gear Box Oil Nick S General Cobra Discussion 19 22-01-08 09:42 AM
Top gear Ricky General Cobra Discussion 43 26-02-07 08:37 AM
Top Gear dave General Cobra Discussion 3 08-05-06 09:03 PM
Top Gear.. pat b General Cobra Discussion 13 13-02-05 02:10 PM
4th & 5th Gear RigMan General Cobra Discussion 7 19-03-02 05:57 PM
