Old 16-05-08, 06:19 PM
Stu J's Avatar
Stu J Stu J is offline
Starter motor
I started the engine today after the overhaul and generally ran smoothly, the hydraulic tappets are still a little noisy.
But the starter was sometimes very slow to turn over and in the end a fuse blew, after the fuse was changed however the starter engaged straight away as soon as the ignition lights were turned to on the key.
All earth straps are ok too
Am I right in thinking dodgy solonoid or starter...?
C an
O nly
B e
R eal
A drenalin
Sumo 3.5 RV8..... megasquirt has arrived, with a date for the SVA too
Old 17-05-08, 11:03 AM
demus's Avatar
demus demus is offline
Hi Stu,
Do you mean the starter engaged when you turned on the ignition, without turning the key to the start position??
Was it ok before the overhaul, are all the connections ok at the starter motor?
Mark
Not sure what drinks more petrol, the car or our cat!!
Old 17-05-08, 11:31 AM
Stu J's Avatar
Originally Posted by demus View Post
Hi Stu,
Yes Mark the engine turns over without going to the start position, I am thinking along the lines of the starter switch maybe... but this is new too and it worked fine before.
It just confused me why the engine turned over slow 4 times out of 6 and is why I thought starter/solonoid at first.
C an
O nly
B e
R eal
A drenalin
Old 17-05-08, 05:28 PM
demus's Avatar
Hi Stu,
If the starter engages when you turn the keys on and releases when the keys are off the solenoid is probably fine.
If it all worked ok before the engine came out I woundn't think there's much wrong, have you double checked the wiring at the starter motor, if the connections are all ring terminals maybe the solenoid wire and one of the lives are swapped. Maybe worth getting a wiring diagram and checking through the starter circuit.
Hope this helps mate,,
Mark
Old 17-05-08, 06:25 PM
Stu J's Avatar
All sorted.....
I put a bigger amp fuse in the circuit which solved the slow turn over and basically there was a short on the starter switch after pulling the dash out previously.
The tapping was not the tappets, it was the half moon gearbox plate catching on the flywheel. After a bit of leveridge from my best screwdriver all is fixed.
I gave myself a big pat on the back after doing the engine overhaul with a new gearbox at the same time too, and it runs as sweet as new with response time out of this world.
The sound with my sidepipes is an added advantage.
C an
O nly
B e
R eal
A drenalin
Old 17-05-08, 07:13 PM
TINKA TINKA is offline
Well done lets hope that is the last of your problems now and you can move on to the SVA. Which office are you going to take your car to?
Old 17-05-08, 07:34 PM
Stu J's Avatar
Hi Martin, yes I will post sva forms after i've sorted the speedo out (don't work) and hope to get tested at the Derby centre
C an
O nly
B e
R eal
A drenalin
Old 18-05-08, 12:11 PM
demus's Avatar
Nice one Stu,
Glad you got it sorted out and glad the engine is running nicely, well done.
All the best for the SVA.
Mark
starter motor v8 sam DAX Technical Questions 2 15-11-06 02:58 PM
Starter Motor pat b General Cobra Discussion 18 03-05-06 04:51 PM
Starter motor 427sc General Cobra Discussion 5 04-03-05 03:48 PM
starter motor lardy General Tech Tips & Questions 4 25-02-03 04:38 PM
Starter Motor Poohbear General Tech Tips & Questions 13 23-12-02 09:01 AM
