Old 19-05-08, 08:47 PM
hfbradley01 hfbradley01 is offline
Fitting Fog & Reversing light to rear bumper
I'm looking for ideas to attach the fog and reversing lights to my rear bumper.
If these can be bought with the correct fittings already supplied then that would be perfect, otherwise I need a method of fixing them to the bumper.
All suggestions welcome.
Howard
Viper under construction - full steam ahead and hopefully on the road this autumn.
Old 20-05-08, 06:58 AM
Toddy Toddy is offline
My fog light is a nice snug fit between the bars so I took it apart and drilled the fog light case top and bottom then did the same to the bumper . Attached with self tappers and rebuilt the light.
Old 20-05-08, 03:46 PM
pelham939 pelham939 is offline
i was looking to use this type of mount with the chrome lamp from europa
badge bar lamp bracket :: Vintage Car Parts
Old 20-05-08, 04:12 PM
Neil O's Avatar
Neil O Neil O is offline
Not sure if the chrome lamp is SVA compliant (if you need it to be).
Crendon, Ford Sideoiler 427
Old 20-05-08, 04:57 PM
nearly thers's Avatar
nearly thers nearly thers is offline
Fog Lamp fit
This has got to be the worst bit to fit on any Cobra. There is no real way of fitting one to look smart (that I have seen yet). Attached are some pictures of my installation for the SVA using a standard motoring accessory shop item and a P clip. Now the SVA has gone I'm looking for an alternative lamp. Make sure you mount it above the lower bar as per my car, below it will probably fail on the height regulation.
Sorry pics are a bit blurred but difficult with my vintage Sony camera to get a good focus close up.
Neil
I should be called "Nearly There" But I was drunk when I joined this club!
Old 20-05-08, 05:26 PM
Clive's Avatar
Clive Clive is offline
My rear fog lamp is located under the rear scuttle and can be folded up out of sight when not needed. (The min height for SVA is 250 mm)
Cheers, Clive
Old 20-05-08, 07:12 PM
Folding lamp
Where did you get that lamp? Looks fairly tidy and I love the idea of folding it up out the way.
Neil
Old 20-05-08, 07:25 PM
madjohnny's Avatar
madjohnny madjohnny is offline
I just fitted a cheap plastic one from Halfords pre sva and then just replaced it with one of these from SVC. I mounted the plastic one with a P clip round the bumper then post SVA drilled the rear of the bumper, rivnut'd the holes and made a aluminium bracket to secure the nice chrome fog light.
Cheers, John.
Drive it like you STOLE it!!
MJ's Gallery
Old 20-05-08, 07:37 PM
andicole0's Avatar
andicole0 andicole0 is offline
It takes how long!
I was going to use the same style lights as the tail lights but fitted to the body between the bumper bars. I was going to check against the SVA regs but haven't done so yet, anyone know of a reason why I shouldn't?
I'm sure I've seen a pic with this done.
Andi.
http://picasaweb.google.com/andicole0 - http://andiscobra.blogspot.com/
Old 20-05-08, 07:40 PM
madjohnny's Avatar
Andi.
Not sure if they will be high enough mounted between the bumper bars. Double check the minimum height restrictions for the rear lights.
Cheers, John.
MJ's Gallery
quicky on rear bumper?? bitsilly General Cobra Discussion 5 24-09-07 08:09 PM
Rear Bumper SVA Phil McCann Pilgrim Sumo Technical Questions 1 17-05-05 02:27 PM
rear bumper classiccapri General Tech Tips & Questions 2 02-05-05 05:07 PM
Rear light fitting beanpole Pilgrim Sumo Technical Questions 7 08-09-03 10:32 AM
Reversing Light Connector Karl Engine Tech Tips & Questions 1 05-09-03 05:03 PM
