Old 21-05-08, 09:04 PM
MarkyC's Avatar
MarkyC MarkyC is online now
Prop Shaft
Just been looking at the prop area.
From UJ to UJ the prop will be 400mm long and will run down to the diff at an angle of about 8 Degrees.
Is this an acceptable slope on the prop shaft?
If not what are the limits?
Cheers Mark.
Dax, Ford 302
I'm not a Gynaecologist
But i'll have a look
Old 21-05-08, 09:10 PM
slogger's Avatar
slogger slogger is offline
Cheers Mark.
Hi Mark. That sounds like a typical Dax setup. Best of luck.
Ian DAX 454 Chevy
Old 22-05-08, 04:20 AM
Dutch Paul's Avatar
Dutch Paul Dutch Paul is offline
You need a bit of an angle to keep the UJ`s working and spreading the grease around the UJ bearings - should be fine.
Prop Shaft digger782 General Cobra Discussion 5 30-11-07 05:01 PM
Prop shaft next cliffords AK Technical Questions 5 17-07-06 07:14 AM
Prop Shaft BenBaron General Tech Tips & Questions 11 15-06-06 04:02 PM
Prop shaft length kevchard General Tech Tips & Questions 5 07-11-04 07:12 PM
prop shaft fitting eams General Cobra Discussion 3 11-10-04 10:57 AM
