Old 27-05-08, 08:32 PM
Veteran polisher.
Stainless steel tubing?
Hi All
When I built my car originally I used the flush type filler cap mounted in the rear deck behind the roll bar. Soon after the SVA I realised I didn't really like it so I fibre glassed in a recess supplied by Dax and fitted a nice Aston type filler in the wing top.
I did stick with the same fuel tank though so what used to be a straight pipe run turned into a long S shape tube. This works fine and doesn't cause any problems during filling but it looks a bit nasty and is quite vulnerable in the boot when doing the weekly shopping.
I would like to weld together a few Stainless steel bends and make a rigid pipe with a short rubber joiner at each end. I could then polish the pipe and the welds to a shine and it will give me something else to use the Autosol on!
Where can I get good quality stainless bends from in 2" size? I have heard of Dairy pipe but anyone know where it can be brought at a reasonable cost?
Polishes to date = 17
Old 27-05-08, 08:43 PM
andicole0's Avatar
It takes how long!
Here's some 2" stainless bends.
Andi.
http://picasaweb.google.com/andicole0 - http://andiscobra.blogspot.com/ - http://www.tomsrush.blogspot.com/
Dax Tojeiro, dead Chevy 350, Tremec TK05, 3.54 Powerloc diff. MoT'd, SVA'd, registered, taxed and insured. Now with RAC cover, just in case
Polishes to date = 2.
Old 27-05-08, 08:53 PM
madjohnny's Avatar
Bought all mine for my exhaust manifolds from Custom Chrome.
Cheers, John.
Drive it like you STOLE it!!
MJ's Gallery
Old 27-05-08, 09:01 PM
These people might be able to help:
Tube Manipulation, Metal Fabrication, Metal Furniture, Balustrade by Pipecraft
I used them some years ago and found them very helpful. They're in West Sussex.
If you can find someone with CNC scanning and bending you can get the piece made up in one which looks great. I had one done for the same fuel filler application (but on a Ram). I have them the crappy welded up job that I'd been using and they scanned it and produced this, a great improvement.
Myles D-W
Old 27-05-08, 10:07 PM
Bought most of my Stainless dairy bends from here Stainless Pipeline Supplies, Oldham - suppliers of stainless steel pipe, flanges and fitting
not sure what the prices are like now but they were £6.90 for the 1.5" 90 deg elbows 4 years ago
Old 27-05-08, 10:10 PM
Veteran polisher.
Cheers guys.
Lots of useful places there. I will have a think about what I want I need and get something made.
Old 27-05-08, 10:15 PM
southenddave's Avatar
Give Gwak a PM as he knows a good bender and has plenty in stock
Where's my fecking bellhousing????
Old 31-08-08, 11:13 AM
Originally Posted by craggle View Post
Hi All
Hi Craig, among other preparations while my body remains un-fitted I am looking at the fuel filler, after a search I saw this thread of yours. Did you manage to improve the filler pipe? Do you think it might be better to reposition the filler neck on my Dax tank? At the moment it has not had fuel in it and I may be able to move it to the side?
I have the wing recess also, not cut the hole yet, the rear wheel arch finishes right in the middle of the filler recess?
is this right??
Cheers Richard
Old 31-08-08, 11:47 AM
is this right??
Cheers Richard
I am helping a friend build his Dax at the moment and he has welded up the original filler hole and it is now been moved to the side, only extra thing we needed to do was to weld in a couple of breathers so that the air can get out when it is filled right to the very top. I did the same mod to my AK and it is surprising how much extra room it gives in the boot not having the fuel pipe in the way all the time, and it works really well when filling up with fuel. HTH
Old 31-08-08, 12:12 PM
Lloyd Barnes's Avatar
I moved mine back a little when I fitted it so it just misses the inner wheel arch and exits in the boot. Probably not exactly correct but think it looks ok. I wasn't sure about wheel clearance if I put it in the arch itself with. I'd planned to do what you and Tinka are suggesting about repositioning the filler pipe.
I was seriously worried about cutting that hole but in the end, its was dead easy. Just bonded the recess to the underside, cut a rough hole and then used a dremel with a little drum sanding attachment. Finished by sanding with paper held to a piece of steel plate bent to the right radius. One of those (few) jobs that went right!!
is this right??
Cheers Richard
Lloyd B
De dion Dax - 383 SBC with AFR 195's, not finished but driveable, frightened passenger count, 1!
Stainless steel tubing ???? darren Pilgrim Sumo Technical Questions 9 18-08-07 04:00 PM
Stainless Tubing Miket General Cobra Discussion 2 15-07-07 10:13 AM
Stainless steel bolts martin_t Engine Tech Tips & Questions 5 11-05-06 11:14 AM
Stainless Steel Bottles etc. BIGUNDIES General Cobra Discussion 8 23-01-06 05:23 PM
Drilling stainless steel Robin427 General Tech Tips & Questions 16 22-06-05 09:59 PM
