| If the bell housing is out I would send it back and get it replaced. Can't believe the block would be out as it would have always caused a problem. I am sure they don't check this out in the factory.
| These measurements are not so important if you are fitting a flex plate and torque converter. Russ. You got it, shim between the block and bellhousing to get a "level playing field", then centralise everything. Job's a good'n.
__________________ Pro Dax Builder Current builds:- Dax No.125---------Kirkham No. 1 |
| Quote:
Russ
| Well i've just come in from the garage, and i'm a little fed up. i clocked the gearbox mounting face and it was 0.004 further out at the bottom than the top, so as a temp measure i used several pairs of feeler gauges and managed to get it bang parallel with the flywheel, great. But no would it be possible for some one to take a photo of the engine side of theirs and take some measurements hole centres ect. Thanks for you time and advice guy's it's all appreiciated. Russ
| Hi Russ, Got mine about three weeks ago, one of the latest batch. All lined up OK first time I am afraid / delighted ( Did you have to wait long? Have just got my clucth plated 12 weeks late. Hopefully if it is f@cked, you won't have to wait long for a replacement. Regards, Dave
__________________ Where's my fecking bellhousing???? |
| Russ Having read your posts I would return the bellhousing and exchange it for another one. Whatever you do, DO NOT DRILL NEW DOWEL HOLES!!!! I did and as a result I'm even more frustrated than I was before. Instead of having one set of pins the same amount out, I now have 2 holes which need to be individually aligned. I've resorted to putting interference fit plugs in the drilled holes, long (2") interference fit bushes in the b/h to counter the hand-drill wobble, lining it up by DTI, clamping, drilling and reaming the new holes to size!!! What I should have done of course was to make up a set of o/s pins in the workshop, but no, I though I was cleverer than that! Doh! I have 20/20 hindsight vision now! Graham
__________________ Trying to find time to work on the Cobra between feeding, entertaining and nappy changing! |
| Just a thought but if/when you get it all to line up, you then have to take it off again to put the clutch in, am I right. Then put back the bellhousing and hope the dowels havent slipped, (unless using the TINKA patented method - this sounds a very practical solution)which when we are talking about such small measures it is possible surely! Thus only one way to be certain and that's weld the washers in place hence permanently align the bellhousing - is this right? Steve |
| Repower Bellhousing | oglyoodoo | Engine Tech Tips & Questions | 10 | 01-05-08 10:55 AM |
| Contacting Repower | cliffords | General Tech Tips & Questions | 4 | 20-04-06 08:04 PM |
| Dialing in Scattershield | bogster | DAX Technical Questions | 7 | 02-03-06 07:25 AM |
| Bellhousing from Repower? | garyholden | AK Technical Questions | 4 | 20-01-06 05:11 PM |
| repower | MR JONES | General Cobra Discussion | 1 | 27-10-05 07:39 PM |
