  #11 (permalink)
Old 06-06-08, 10:57 AM
Originally Posted by KevinW View Post
I meant something like this
CHB
- I assumed it was a 3 piece, may well be wrong?
No that is a three piece
  #12 (permalink)
Old 06-06-08, 03:43 PM
Dutch Paul's Avatar
I remember at the GD trackday (last year?) somebody losing half a wheel.
Not sure whether it was an Image wheel or not, but apparently, if my memory is right, it was due to the wrong thread inserts being used in production.
There was a thread on here somewhere.
It`s maybe worth checking on if you have 3 piece wheels.
  #13 (permalink)
Old 06-06-08, 03:55 PM
Dutch Paul's Avatar
Found it..........
Image Wheels Check your dates !!!
  #14 (permalink)
Old 09-06-08, 12:50 PM
If I recall, undoing all the bolts (the 31 that are left) should mean the centre pops out. I'll deflate the tyre first so it doesn't burst the silicone that is inside the rim as to be fair, I've had no leakage problems since resealing it myself. I'll then be able to clean out all the threaded inserts (which have a lot of silicone in them) and get better access to the sheared fasteners, which hopefully won't be in too tight). I'll then reassemble with new bolts and threadlock them all in.
Anyone know if there is a specific torque to use?
Also, I'm not impressed with the star washers - many of them have broken. Would normal spring washers be better?
Reverend Robin
GD427 Euro
World Rivnut Champion 2007
  #15 (permalink)
Old 09-06-08, 05:16 PM
dave's Avatar
Tuuurn up da bass.
The normal split rims are (i think) 15ft lb but I think you should contact image over the torque settings to be on the safe side.
Pro Dax Builder
Current builds:-
DB REPLICAS
Low Volume manufacturer
  #16 (permalink)
Old 09-06-08, 08:11 PM
Personally, I would have sent the whole wheel back to Image for a free repair.........
  #17 (permalink)
Old 09-06-08, 09:12 PM
RichardG's Avatar
Yep, what he said!
Richard
Welding my bits together
  #18 (permalink)
Old 09-06-08, 09:23 PM
Problem was, Wilf, that they did such a gash job on it, I wanted to redo it myself. I reckon the acid in the silicone might have corroded the bolts, but this time I'll be assembling it dry (i.e. no silicone but with threadlock)
Have popped the centre out without too much hassle this evening, although discovered another bolt had sheared. Have got to drill out 4 bolt stubs now - leaving it in soak with WD40 overnight - will attack tomorrow as I doubt this fantastic weather is going to last for much longer...
Reverend Robin
GD427 Euro
Image wheel coating Wilburn General Cobra Discussion 4 07-03-08 11:43 AM
Are image the best ? kurrmet General Cobra Discussion 11 16-01-08 07:18 AM
Image Wheel Nuts Covers rangrov General Tech Tips & Questions 16 07-12-05 07:30 AM
Front Wheel offset problem maverick General Cobra Discussion 0 22-06-05 10:52 PM
Image Wheel Spinner replacements StuartH General Tech Tips & Questions 1 25-02-02 11:44 AM
