Old 17-06-08, 07:53 AM
martin_t's Avatar
Fitting Electric Fan
HiCan anyone advise on the fitting of a Fan to my GD based Cobra? I have a Rover engine and a Rad provided by GD which I have fitted all ready. Is it best to have the fan in front or behind the rad? Also, what is the best way of attaching it? I have read on the forum that the "pull through" type fitting provided with most Fan kits can damage the rad. What is the best option instead of that?ThanksMartin
GD427 Mk4 - Chassis rolling.
MK4 Body ordered (in black)!!
GD Chassis J0258.
www.martins-cobra.co.uk
Old 17-06-08, 08:02 AM
Cooling fans work better if they pull air throught the radiator - you will need to specify that when you order yours. Also, mounting the fan to a bracket is a better idea than the "kenlowe" type through-radiator fixings, which have been known to damage radiator matrices. (because they get loose and let the fan move up and down with road shocks)
Old 18-06-08, 12:20 AM
fly fifer's Avatar
fixing fans
Martin
this is how i did mine.........cooling a rv8
fixing fans to the radiator
hth
Steve
as Earl would say............it's Karma
Old 18-06-08, 09:08 AM
whatever method you use, just make sure to prevent any possibility of chafing or fretting of the fan against the rad, as the fand do tend to vibrate a little, and the ali won't take much to wear or crack.
as you have gathered already, the "through the fins" fitting tends to induce leaks for some, and is easily avoided with a little work
If you have the GD rad, in ali. there is plenty of room to add fan mounts on the top and bottom rails
Steve - AC 04 COB
Old 19-06-08, 08:01 AM
martin_t's Avatar
Smile
Hi Steve
It's not an ally rad but I did get it from GD. There seems to be some space top and bottom, and looking at SimonR's blog that should be enough. Bit scary with a drill though, could really mess it up if I'm not carefull!!
GD Chassis J0258.
Old 19-06-08, 10:52 AM
put a thick offcut of metal behind where you are drilling to protect the rad..........
the drill can catch easily on thin sheet and pull through
Steve - AC 04 COB
Old 20-06-08, 06:05 PM
davidcot's Avatar
Thumbs up GD rad fit
Martin
I have a GD and altered the rad by adding 2 lengths of steel rod top to bottom (local rad repair shop did it ) and fitting rivnuts to attach the spal low profile fans.
David
Old 22-06-08, 01:44 PM
Simon R's Avatar
Originally Posted by martin_t View Post
Hi Steve
Martin, there's nowt behind there - drill away!
Simon
GDJAG
Chassis Now Rolling!
BAE 383 SBC in and running
MKIV Body fitted
What's Next ... SVA? or IVA? probably IVA!
http://str-427-cobra.blogspot.com/
Gas v Electric JonnyT General Cobra Discussion 25 11-05-08 09:14 PM
AC Electric Cobra alfiebeard General Cobra Discussion 7 20-07-07 08:40 PM
electric speedo stevemat General Tech Tips & Questions 5 13-07-05 04:38 PM
electric car heaters the4bidden General Cobra Discussion 6 27-01-05 01:37 AM
Electric Horn Phil McCann Pilgrim Sumo Technical Questions 3 10-09-04 02:44 PM
