  #21 (permalink)
Old 19-06-08, 10:04 AM
lutman's Avatar
Originally Posted by JonnyT View Post
I'm not sure any of the above really explains why it would go to the floor the first time and then bite firmly though, and then do the same again next time you use the brakes.
It sounds almost as if fluid is being removed from the system whilst the brakes are not being used and requires pumping to get the additional fluid into the master before the brakes bite. That in turn sounds like there might be air in the system otherwise it wouldn't happen as all that would be sucked back would be fluid unless a vacuum is being created in the system somewhere.
Jon
Was it a secondhand or new/reconditioned servo unit ?
I had a servo assist on an MG which occasionally used to give strange results depending how I applied the brakes.
Do you have the same flat to the floor feeling when you " emergency brake" stomp on the pedal as opposed to normal application?
Chris Lutman - Daytona Coupe
  #22 (permalink)
Old 19-06-08, 11:26 AM
wsnaith's Avatar
Hi Chris
It was abrand new servo supplied by Dax.
I'm going to re-bleed the brakes today and then go for a little run.
I'll let you all know how I get on
Warren
Dax De Dion, 350 Chevy V8, 355bhp - AC58COB
Bedding in the brakes chedz General Cobra Discussion 15 10-07-07 09:45 PM
ABS brakes. Steen General Tech Tips & Questions 0 03-09-06 10:53 AM
Jag Brakes kelsey General Cobra Discussion 6 17-01-06 08:23 PM
Bedding in brakes Robin427 General Tech Tips & Questions 15 21-09-05 09:48 PM
Which Brakes r0lex Pilgrim Sumo Technical Questions 4 17-07-05 09:29 PM
