| I am trying to fit a new dizzy to my RV8 and the only position that allows me some timing adjustment means that the vacuum chamber fouls the thermostat housing. Does anyone know of a housing with a different outlet or will I have to get it moved and welded? I hope that the photo will give some idea of my layout. thanks John |
| Hi Dave, If I do that the electronic module opposite the vac chamber fouls on the valley gasket clamp! You can just see the module on the red and black leeds near the bottom of the picture. John |
| Move your plug leads around the distributor cap by one space anti clockwise, then reposition the distributor body so that the No 1 aligns up with the Cap again. Just needs a little lateral thinking.............
| Quote:
John, We sell a modified thermostat housing that will allow you to turn your distributor further clockwise and get timing alignment. If you want to give me a call tomorrow, I should be able to help. Regards Jim
__________________ www.jrv8.co.uk |
| Quote:
Do you have a photo of the thermostat housing? David
__________________ David Large Bald Surfer with a BRA 289 |
| I think David was after a picture of Jims modified thermostat housing. I still think it should fit though. Don't forget you can remove the distributor and rotate the shaft one tooth on the drive gears. My Range Rover had a similar distributor and that was mounted in the same orientation you have your one. Must be a way to get it lined up somehow? Craig.
| Thermostat & Housing | Martyn-ak427 | Engine Tech Tips & Questions | 15 | 09-02-07 09:24 PM |
| Need a new SD1 Thermostat housing | Dave Williams | Engine Tech Tips & Questions | 9 | 03-11-06 08:37 PM |
| Thermostat housing | BenBaron | Engine Tech Tips & Questions | 3 | 18-09-06 04:39 PM |
| V12 Thermostat Housing???? | nearly thers | General Tech Tips & Questions | 0 | 21-11-05 10:46 AM |
| thermostat housing | graham | General Tech Tips & Questions | 10 | 05-12-02 07:56 PM |
