Old 21-06-08, 07:18 PM
ceejayjay's Avatar
Too much backfire on the overrun
My 454 Chevy has always produced a pleasing belch of flame under hardbacking off of the throttle but now pops a bit more than I would like even under gentle throttle off. No discernible change in running or performance, and my best guess is either a dodgy plug going slowly on the blink or dud wire. The plugs ara a total bastard to get at!!! - need three different bits of cobbled tools to do!! so don't want to go that route if its being caused by something else.
Thoughts?
Carb untouched by human hand and has been dead reliable - holley 750 double pumper.
Thansk
Chris Jackson
Ram 427SC
460ci Chevy and 435bhp. My very own white knuckle ride!
Old 21-06-08, 07:20 PM
Clarkson's Avatar
Speed junkie
Sounds like you have a exhaust air leak??
David
2nd baby due 23rd Jan.
Old 21-06-08, 07:27 PM
ceejayjay's Avatar
There's a thought. If so maybe most likley where the manifold enter the 4 into one I'd guess. Both are in A1 nick but maybe not where they join up? Worth a look.
Chris Jackson
Ram 427SC
Old 21-06-08, 08:15 PM
Clarkson's Avatar
Speed junkie
If it's not right there it will definitively make your sidepipes backfire.
David
Old 21-06-08, 09:01 PM
ceejayjay's Avatar
thats tomorrow morning sorted then
cheers
Chris Jackson
Ram 427SC
Old 22-06-08, 10:18 PM
conrod's Avatar
Chris,
From recent personal experience () it could also be due to a leaking inlet manifold gasket. I had almost cured my "popping on the overrun" problem by replacing an exhaust manifold gasket. Then the engine developed a very loud screeching sound due to a vacuum leak. Replacing the inlet manifold gasket cured that one, but also finally eliminated the overrun popping/banging problem.
Hope this helps.
Alan
Thames Valley Area Rep
My Gallery - click here
My Albums - click here
Old 23-06-08, 12:45 PM
427scr's Avatar
Any air leak into the induction system will cause a backfire.
my car runs a pair of SU's and used to belch flame every time I let off.
I serviced the carbs, including new throttle spindle rubbers and it stopped doing it!
SBC chevy 305 pops on overrun AC427 General Tech Tips & Questions 20 24-09-07 10:01 PM
Backfire kobra Engine Tech Tips & Questions 6 28-04-07 10:53 AM
Backfire BIGUNDIES General Cobra Discussion 4 19-05-06 10:58 AM
Backfire V8 BJC General Tech Tips & Questions 11 22-04-06 04:32 PM
Diff noise on overrun arm Pilgrim Sumo Technical Questions 0 03-04-06 10:55 AM
