| Search facility on the forum is your friend. Gearbox Oil Early 4 & 5 speed models used SAE75W oil. From approximately 1980 onwards, Rover used automatic gearbox oil (ATF) in the manual gearbox, to help improve gear selection from cold. Our reconditioned 5-speed gearboxes use ATF. The oil capacity is 1.5 litres.
| Lt77 Oil Quote:
I would use 75/90 full synthetic oil the type I use in mine is Mobil I , I would'nt use ATF it was only used to help cold gear selection, and exagerates wear on the bearings, the filler plug is near the tail of the gearbox and is also a level plug so just fill it until it runs out. HTH Alfie B
__________________ Blue Sumo Mk111 RPI 4ltr crossbolt V8 Piper cam Webber 4 barrel freeflow headers Mallory dizzy Jag running gear with powerlock Diff. |
| Quote:
Copied from the Rimmer Bros site and taked from my post by MrT Search thingy is gooooood!
__________________ Ian DAX 454 Chevy The closer I get to getting it running, the further away I actually am!! |
| "1980 onwards, Rover used automatic gearbox oil (ATF) in the manual gearbox" But note that LR suffered so much warranty with ATF in the boxes, that they later engineered their own trans oil spec (with Texaco?), MTF94, specifically for this box. Improved cold shift AND the benefits of 'proper' oil for lubrication. MTF94 is a semi synth 75/90 gear oil . . . . Russ |
| T5 gearbox | Harry-G | General Tech Tips & Questions | 14 | 14-08-06 06:38 PM |
| Gearbox ID help | Speedy Gonzales | Newbies | 12 | 13-02-06 04:13 PM |
| Gearbox ??,s | Shaney23 | General Tech Tips & Questions | 0 | 10-09-03 09:48 PM |
| gearbox | Bernie | Engine Tech Tips & Questions | 11 | 08-09-03 01:26 PM |
| SD1 gearbox Oil ? | beanpole | Engine Tech Tips & Questions | 2 | 03-05-03 07:12 PM |
