Old 22-07-08, 10:36 PM
JohnWoodman's Avatar
Talking On the road at last
Another Dax hits the road at last. Got my age related plates last week. This week has been great, the first real break in the weather and the trips to and from work have been emense fun. I'm just waiting for the crowds of people to die down a bit at lunchtimes.
Anyway, I have now done about 400 miles and here is the shake down list
1) That crap ford steering bush at the bottom of the steering column keeps working its way up the steering column. I have put a jubilee clip around the triangular section to prevent it moving for the time being. I think I may replace it with a proper roller bearing at some point. Has anyone else had this problem?
2) I have four puddles of oil that collect around the 4 centre inlet manifold bolts (2 on each side). I'm assuming the oil is coming up the threads, but I thought the only oil that high in the engine would be coming up the pushrods to oil the rockers. I'll try thread sealing the bolts to see if it stops. Again has any one else had this problem?
3) Squeak from the rear brakes. When I'm driving along I get an intermittent squeak which increases in frequency with road speed. If I brake it goes away. So I'm assuming it's a pad not coming away from the disc properly. I've had a look at the pads and they seem free enough. I'll try bleeding the rear brakes to see if that solves it (could be an air pocket preventing the piston from being sucked away from the pad). The plates that the pads are mounted on slide on pins do you normally grease the pins? I assembled mine dry.
4) Still have the fuel leak in the tank, I'm pretty sure it is comming from one of the welds holding the baffles in place. It's only a problem when I fill the tank above 3/4 so I'm currently only filling to 1/2. Dax have said they will have it back and re-pressure test but I want to do a few miles in my new toy while the weather is nice. As soon as it starts raining I'll drop the tank out and have a better look. Someone said dusting it with talcom powder will show where the leak is coming from so I'll try that also.
Happy motoring for now
John
If you drive a Cobra you are going to get wet.
Dax Toj 350ci Chevy, Tremec TKO600, 5" Sidepipes
Old 22-07-08, 11:51 PM
wsnaith's Avatar
Hi John
Can't wait to get mine on the road also.
With regard to the bush on the end of the the steering column I had the same problem - actually caused a fail point at SVA as the steering was really heavy and it wouldn't self centre
Spoke to Peter at DJ and he said it was a common problem - solution - whilst the bush is up and unseated put some black grease around it. Force it back down into the seating and then hold in place with a big dollop of wurth
I did just that and although I've only driven back to the SVA centre and back it hasn't moved!
warren
Dax De Dion, 350 Chevy V8, 355bhp - AC58COB
Old 23-07-08, 08:47 AM
Club Sec/Rep Liason
Well Done John Here's a better solution for the steering column bush (and not a drop of wurth in sight) Supporting the steering shaft
AK 427 351C T5wc
How much road tax eng622 General Cobra Discussion 11 24-03-07 01:33 AM
New used car no road tax. shadow The Cockpit 13 31-01-07 09:41 PM
Yet another F1 car for the road ...... mark_biddle General Cobra Discussion 0 10-02-06 10:53 AM
On the road........actually Revets General Cobra Discussion 3 07-10-05 06:49 PM
End of the road.... breskit General Cobra Discussion 10 18-06-04 11:07 AM
