| On the Rover it refers to the type of drive belt used on the front of the engine. The earlier Range Rovers and SD1 engines used standard V belts. My 4.2 Range Rover had 4, Vee belts, One for the water pump, one for the power steering, one for the alternator and one for the air con pump. The later engines used a single multi vee belt which is about an inch wide with 6 grooves running right around the inside of the belt. This single belt snakes it way around all the accessories and drives everything at the same time. There was two stages of serpentine development. The late Range Rover classics with the 3.9 and 4.2 engines had the same timing cover with a distributor but used the multi Vee belt. The later P38 type 4.0 and 4.6 engines had a different timing cover with a crank driven oil pump and no distributor. The main engine on all these motors is basically the same but the timing cover, Crank pulley and water pumps change according to age. Serpentine water pumps are also driven from the back of the multi Vee belt so they rotate in the opposite direction to the earlier V belt ones. And Wilf types faster than me! Craig.
__________________ Dax Tojeiro, + 350 Chevy + Tremec box = no more money! Polishes to date = 17 Last edited by craggle; 31-07-08 at 09:59 AM. |
| You might have issues if you intend to fit a serp engine into a cob, I know on the sumo that there's very little clearance between the front pulley and the chassis even with a non-serp engine. It's pretty close to the steering rack to! As far as I know (which ain't much) the blocks are the same, you can therefore convert a serp block into a normal engine but it won't be cheap to buy the front cover, pumps etc. The crank nose lengths are different but again it is still possible. Pete
__________________ I refuse to engage in a battle of wits with an unarmed opponent. Last edited by Sidecarbod; 31-07-08 at 10:38 AM. |
| As already mentioned by previous collegues - the ' serpentine' system is the name of the drive belt system - its more flexible and a flatter belt profile as opposed to the v shape most of us are used to. It was developed by NASCAR racers to be more reliable at higher revs and under higher loads. Downside is the expense - you cannot fit a serpentine belt on standard pulleys, but its a good opportunity to replace the existing pulleys with polished alloy units.
__________________ Chris Lutman - Daytona Coupe |
| Quote:
| Quote:
| Hi Chris On the Rover the pulleys are a bit different and can't be dismantled. I always thought the standard Range Rover serpentine system was actually shorter that the Vee belt setup of the SD1 but not looked too closely at it. Can I ask what make you manifold and throttle bodies are? Craig.
| Quote:
TVR GRIFFITH/CHIMAERA V8 5 LITRE ENGINE 15100MILES 1998 on eBay, also, TVR, Car Parts, Cars, Parts Vehicles (end time 06-Aug-08 21:37:08 BST) |
| If it has been totalled there could be damage to thrust bearings. Always worth knowing just how it got totalled - i.e. the direction of the sudden deceleration.
| Old Engine is Junk, New Engine Time - what to look for...? | bc_suv | General Tech Tips & Questions | 7 | 27-04-08 10:29 AM |
| alloy serpentine pulleys | mb evo | General Tech Tips & Questions | 7 | 30-12-07 11:35 PM |
| Piper SD1 cam in a serpentine block? | alastaid | Engine Tech Tips & Questions | 9 | 03-12-04 08:50 AM |
| Has anyone imported an engine from Engine Factory.com | dave | General Cobra Discussion | 6 | 01-11-01 11:17 AM |
