| Fuel Tank Breather What is the consensus with fuel tank breathers for carb fitted engines? I have seen some threads with discussion of very smart non-return valves in a breather pipe, or some with a just a length of pipe fitted. What is necessary/advised for road use only? Appreciate your wisdoms QK |
| My set up same as Pauls. Drilled out a 10mm bolt then drilled and tapped in to filler neck, turned down end of bolt to suit breather pipe, hose clip, jobs a goodun.
__________________ 383 Stroker power plus Anti-roll bar.....like being chained to a mad dog!! :-} There is no such thing as bravery.....only degrees of fear!! |
| Sumo fuel tank and expansion tank, chevy pump | laosui | Parts for sale | 0 | 10-08-07 09:51 PM |
| Fuel tank sender/fuel gauge | Dek | General Cobra Discussion | 3 | 16-05-07 10:34 AM |
| Fuel tank breather fitting | nbracken | General Tech Tips & Questions | 4 | 03-05-07 11:23 PM |
| Fuel tank breather | BenBaron | General Tech Tips & Questions | 14 | 10-03-07 06:46 PM |
| Fuel Tank Breather. | Trigger | General Tech Tips & Questions | 2 | 15-02-04 10:16 PM |
