Old 13-08-08, 12:58 PM
RCCob's Avatar
SRV8 Build manual
Hi Guys , dose any one have a copy of the SRV8 Build manual, as I need to find out the settings for the suspension caster angle, toe, and camber. I have been having problems braking and general handling.
Cheers Russ
Old 13-08-08, 01:53 PM
chiffer's Avatar
Cheers Russ
Hi Russ,
Just had a look in my build manual, but sorry. It does not give any settings. Try ringing Madgwick, they might be able to help.
CHRIS
Gardner Douglas Mk3, Chevy 350, 420bhp.
Black and looks the business
Old 13-08-08, 03:06 PM
RCCob's Avatar
Originally Posted by chiffer View Post
Hi Russ,
Cheers for looking, Just rang Madgwick and spoke to a very nice guy there and he has told me on the early cars suffered from misalignment on the front suspension mounting points. This would explain the 3 washers packing out the the upper wishbone on the passenger side. The setting should be; Negative Camber 1/2 - 3/4 degree, Caster angle 4 - 6 degree, Toe 10 minutes approx 2mm. He also told me the shocks are fitted with 10" springs which doesn't allow the ride height to be setup properly, they should be 8". I need to replace the rear shocks any way so this is the Ideal time to make the proper adjustments and check the setup. More time spent sat on the garage floor, that will please the wife I might just send if to Track Developments, less hasel and only a couple of hundred for a proper job.
SRV8 Build mikeday General Cobra Discussion 24 18-10-06 11:20 PM
GD Build Manual? pcoghlan General Tech Tips & Questions 3 21-05-04 12:20 PM
RAM Build Manual KenT General Tech Tips & Questions 4 03-10-03 11:25 PM
Dax build manual. tony General Cobra Discussion 2 06-09-02 05:31 PM
SRV8 build graham General Cobra Discussion 2 02-10-01 02:33 PM
