Old 17-08-08, 05:24 PM
Clutch fork location
Hi Guys,
Just doing the final assembly of the bellhousing and clutch assembly after dialling in the bellhousing.
I've fitted a standard pivot ball with just a spring washer under, but when the clutch fork is fitted it is already half toward the front of the opening.
Set up is Tremec bellhousing, Centreforce clutch and standard Ford clutch fork, release bearing and pivot ball.
Does this sound OK or should I fit a large flat washer under the pivot bolt to try and bring it back a bit??
I notice Chevys have an adjustable pivot ball version, why not for Fords??
Best regards,
Richard Dear
GD427J0217/Mk 3 body/Ford 351W Engine Factory/TKO600/3.54PL diff/S-type narrow rear drive shafts. It's going to be red!!!!
Old 17-08-08, 06:01 PM
dingocooke's Avatar
you can buy an adjustable pivot for Fords too but the std Mustang type you have in your pic is just fine and can be shimmed out to get the fork in the right place
Steve
We're here for a good time...
Clutch Release Fork Martyn-ak427 General Tech Tips & Questions 1 04-03-07 03:55 PM
ford clutch fork aero340 DAX Technical Questions 0 29-07-06 09:59 PM
Clutch fork adjustment richardd General Tech Tips & Questions 33 19-01-05 11:41 PM
Which clutch fork. jarv General Tech Tips & Questions 22 31-03-04 09:39 PM
Looking for a Clutch Release Fork Iain General Tech Tips & Questions 4 07-07-03 11:53 PM
