| exhaust isolation Hello, I'm replacing the exhaust on my Cobra and it has to be fitted close to the body (3cm). As it might get quite hot, I wanted to put an isolation in between. Does anyone know what to use? Many thanks Serge |
| Fresh air is a very good insulator so 30mm of it is plenty. I have about 10mm clearance around the header pipes as they come through the body and it hasn't caused any damage to the paint yet. Headers are also a lot hotter than the side pipe itself is. If your fitting underfloor exhaust and want to keep heat away from the floor then you can get thin fibreglass type mat with a reflective aluminium foil on one side. I have this lining my transmission tunnel and it stays cool at all times. It came from Think automotive I believe. Craig.
__________________ Dax Tojeiro, + 350 Chevy + Tremec box = no more money! Polishes to date = 17 Last edited by craggle; 18-08-08 at 10:43 AM. |
| Indeed I will use it for the underfloor isolation. Many thanks for your quick help! Serge |
| AK exhaust on a Dax? | Wilburn | General Cobra Discussion | 10 | 08-11-07 10:18 PM |
| GD exhaust | russj | Newbies | 19 | 12-12-04 11:14 PM |
| gd exhaust | craigh | General Tech Tips & Questions | 6 | 03-11-04 08:39 AM |
| red exhaust | mikeb | General Tech Tips & Questions | 7 | 02-07-04 11:16 AM |
| RV8 Exhaust | Phil McCann | Pilgrim Sumo Technical Questions | 3 | 02-04-04 07:44 AM |
