| Clutch slave bracket Hi Guys, Do I need to incorporate a return spring into the slave cylinder bracket to pull the clutch fork back off the clutch plate when the pedal pressure is released? I can see that the springs in the clutch will force it back until the clutch is fully engaged but that would still leave the thrust bearing just running on the clutch fingers. Do I need a return spring in parallel with the slave cylinder just to get it a couple of millimeter's away?? Or is it meant to stay in contact???
__________________ Best regards, Richard Dear GD427J0217/Mk 3 body/Ford 351W Engine Factory/TKO600/3.54PL diff/S-type narrow rear drive shafts. It's going to be red!!!! |
| Hi Guys, Should review previous Threads before asking questions!!! Just read Daxmans thread on clutch throw out bearing!!! But would an additional spring just help???
| Clutch slave | Sparticus | General Tech Tips & Questions | 39 | 20-04-07 09:26 PM |
| Mcleod Slave Cylinder Bracket | bogster | General Tech Tips & Questions | 10 | 15-04-06 08:56 PM |
| Slave Cylinder & Mounting Bracket | bogster | DAX Technical Questions | 9 | 13-05-05 08:34 PM |
| Clutch slave | Goldie | AK Technical Questions | 5 | 23-09-04 11:36 PM |
| Dax Clutch slave cyl. | DavidSaw | General Cobra Discussion | 2 | 20-08-02 11:00 PM |
