Old 27-08-08, 07:35 PM
srv8dave's Avatar
Question Charging problem.
I could do with some advice of an electical nature.. On my newly built SRV8 I have only managed 63 miles before the snags came thick and fast, the only one I cant solve is the alternator wont charge. With the engine turned off I have 12.7 volts across the battery, on starting the ignition light glows and wont extinguish along with the battery showing 12.2 volts using a multimeter and the car's voltmeter. Revving the engine makes no difference and the alternator was repaired last week (I also witnessed the test at 14 volts @ 2500 RPM). The battery appears to be in good nick and all connections tight with a tight belt. The other problem, possibly related is the fuse for permanent live feeds is blowing.
Any help apprecitated or at least a hand to push it into the sea as I am bamboozled.
Cheers, Dave.
Old 27-08-08, 07:42 PM
Veteran polisher.
Where's this fuse that blows located?
Is it between the alternator and the battery?
Polishes to date = 17
Old 27-08-08, 07:44 PM
srv8dave's Avatar
It's the brown wire from the battery that feeds the purple wires (permanent live) after the fuse
Old 27-08-08, 07:47 PM
Veteran polisher.
So everything in the vehicle runs through this one fuse? What rating is it?
Old 27-08-08, 07:53 PM
srv8dave's Avatar
No mate, It feeds the hazard lights and sidelight relay. It's rated 10 amps. The loom is a 'rapidfit' version from SVC, all was fine till the other week!
Dave.
Old 27-08-08, 07:56 PM
Veteran polisher.
Ahhh, I see now.
In that case I would say the alternator has given up again but strange why it should happen so soon after repair.
Can you remove it and just get it tested again?
Old 27-08-08, 07:58 PM
srv8dave's Avatar
Took it back to the repair guy this afternoon and all was well much to my frustration...
Old 27-08-08, 08:01 PM
Veteran polisher.
I assume the battery is starting the car OK or does it need constant charging?
Just wondering if the battery may be knackered but they usually try to charge.
Old 27-08-08, 08:03 PM
srv8dave's Avatar
It starts on the button, it seems the bamboozling is spreading! The battery is only a few months old, it has to be something simple but what I have no idea as yet.
Old 27-08-08, 08:07 PM
Veteran polisher.
Your not helping here Dave.
Sounds like your cars perfect.
Charging problems ianhunter Engine Tech Tips & Questions 3 11-05-08 08:08 PM
Congestion Charging aka TAX! wilf The Cockpit 13 06-01-07 02:23 PM
Battery charging davep General Cobra Discussion 2 05-06-06 06:02 PM
Is my battery charging? saviller General Cobra Discussion 9 01-09-05 09:40 PM
re: charging upgrades neil still building it General Tech Tips & Questions 0 25-02-05 02:56 PM
