Old 27-08-08, 09:35 PM
Question Chassis Plates and numbers ?
Hi Gents
My Car is ready for the SVA test and I need to commit to a Chassis Number.
But I'm getting some conflicting info on Chassis plates and Numbers and hope that you can clarrify one or two things as I can not get a diffinative direction from previously posted threads.
1) it appears to be gamble as to whether the chassis number should be on a Plate or stamped directly into the chassis. Should I do both to ensure that I get it right ?
2) Do I need an additonal plate attached to the Body work ( Engine bay/ bulkhead) ?
3) How many figures do I need to compile my unique Chassis Number ie 13 or 19 figures ?
How does the following sound.....COB 6O13 441 J8J
4) should I avoid O and 1 ? which would be a shame as it is similar to the original chassis Numbers used by AC.
5) can I stamp the 8 digit 'engine number' as marked on my chevy engine onto the chassis plate as there is a pace for it ?
6) What should I do about the 9 digit 'partial VIN number' which is on the Engine block ( next to the engine numer), do I need to remove/ strike through ? or can I just leave it there ?
many thanks
Steve
Old 27-08-08, 09:50 PM
Veteran polisher.
Stamp the number in the chassis itself. A local AK builder to me had his car rejected at DVLA inspection as the plate was only riveted on. We ended up stamping a plate and welding it to the chassis.
The Dax chassis is stamped directly and they also give you a pre stamped aluminium plate. I attached this to the chassis with rivets but they also wanted to see the stamped number.
Body numbers and engine numbers are not needed on a plate but no reason why they can't be added.
There is a Body number plate on the bulkhead of my car but this wasn't recorded by the DVLA
About all I know about the subject I'm afraid.
Polishes to date = 17
Old 27-08-08, 10:01 PM
Stu J's Avatar
club supporter gold
The number has to be 17 digits, I put PS (pilgrim sumo) 2003 (chassis year) and then my phone number including code backwards.
It is on a chassis plate on the baulkhead
C an
O nly
B e
R eal
A drenalin
Old 27-08-08, 10:24 PM
Veteran polisher.
Can you ask the current owners of Ram for a number? Is there a current owner of Ram.
I heard that someone called Cheng lim plays with them a bit. Maybe he could give you a number.
Thunder Road Cars, The Home of the Cobra Replica
Old 27-08-08, 10:48 PM
alfiebeard's Avatar
Location: Annan Dumfriesshire and work in Carlisle Cumbria
chassis number
Hi steve,
I had my Cob rejected at a DVLA inspection as I only had the 17 digit number on a riveted stamped plate on the bulkhead, the inspector told me the correct place was on the front offside chassis leg or suspension support and it must be stamped in, I whipped it down to my mates garage and stamped it into the suspension support and took it back and it passed.
HTH
Alfie B
Blue Sumo Mk111 RPI 4ltr crossbolt V8 Piper cam Webber 4 barrel freeflow headers Mallory dizzy Jag running gear with powerlock Diff.
Old 27-08-08, 11:03 PM
Stu J's Avatar
club supporter gold
Might I just add, it was stamped on the chassis by the engine too.
C an
O nly
B e
R eal
A drenalin
Old 27-08-08, 11:31 PM
Clive's Avatar
"On mass produced cars in the EC there will always be a 17 character number starting with three letters - the "World Manufacturer Identity". The rest of the characters are used to denote model, variant, assembly plant and whatever other information the manufacturer desires. As far as the amateur builder is concerned, the Vehicle Inspectorate will accept ANY reasonable combination of letters or numbers comprising more than 8 characters. As an amateur builder, you might have been assigned a number with the kit or you might have to make your own up. Make sure you choose a combination not likely to be repeated by someone else - for example "00000001" will be unlikely to satisfy the Vehicle Inspectorate. If for any reason, they don't like your choice of number, they will assign you a DVLA number. These numbers always start "SAB****" and consist of 17 characters. The only drawback of such numbers is that these are the series the DVLA usually allocate to re-shelled mass production cars so the Police often concentrate their searches for stolen vehicles on these cars. We're not saying it will happen but you might get more than your fair share of attention from the local constabulary if awarded one of these!"
(Total Kit Car. "A Guide To Single Vehicle Approval - SVA" Nov. 2003)
Cheers, Clive
Old 28-08-08, 09:02 PM
Thanks Gents
My Conclusion is to to stamp my Number into the Chassis and rivet on the chassis plate I have , ie cover all odds.
the Ram chassis number is only 6 digits, so I will incorperated it into the number I decide on.
Thanks for the addvice
Steve
Chassis numbers bitsilly Ram Forum 5 04-06-08 09:40 PM
Punching chassis number on chassis cliffords General Tech Tips & Questions 16 11-05-08 10:22 AM
RAM chassis numbers my250gt Ram Forum 12 11-08-06 11:32 AM
chassis plates Clarkson General Cobra Discussion 1 17-02-03 10:20 AM
Chassis numbers simon General Cobra Discussion 3 20-02-02 07:45 AM
